1951 John deere A
Hill billy
07-11-2007 00:19:11
Ok here"s the deal, one day i drove the A down the road for about 1 hour. The next day when i need to take it in to a parade that we have in town it shuts down on me. I didnt even get it out of my drive way. There wasnt a bang or any strange noise. It just shut down like i had switched of the ignition "which made sure I didnt do". So i tried pull starting it and that was useless. So I don"t have any idea as to what is wrong. Any ideas will be great.
Hill billy
07-13-2007 19:11:42
 Re: 1951 John deere A in reply to Hill billy, 07-11-2007 00:19:11
I got it running. all i did was change plugs, fuel, and switched the plug wires at the distributor. Thanks all for posting your ideas. We'll see how long she stays running this time... :-
johns48jdb
07-12-2007 04:47:47
you didn't say if it had gas or not. if not, then check the oil level and be sure your crank case isn't full of gas from a hung needle valve in carb.
Dan in Pa
07-11-2007 16:32:53
You say there is spark so your problem might be fuel. Remove the fuel line at the carb and place in a container and then open the shutoff, see if you have a good flow for at least 10 seconds.If there is a good flow reconnect the fuel line and open the carb fuel bowl drain plug and see if ther is fuel getting to there. If that checks ok then you could have a blocked carb nozzle or one of the fuel passages could be plugged but even if one was blocked it should still run, not very well but run. Check out and post back.
Dan in Pa
07-11-2007 15:40:41
Since your tractor is a 51 I am going to guess you are running a distributor. Check and see if there is voltage at the points ,if not replace condenser, if you have voltage at the points but no spark at the plugs you may need to replace the coil. I really think the condenser will be the culprit in your case as I have had the same problems more than once and that is what it turned out to be.
Bobl1958
07-11-2007 08:15:05
Sounds like a deal I had happen last week on my '44 A. Was running great and all of a sudden died. I checked and had no spark, so pulled the cap off the mag. The rotor, (arm in the parts book) had broken and fallen off the shaft. Weird, I realize, but that's what happened. I would say to check to see if you have gas and spark.
John VB
07-11-2007 06:13:31
Not being a wise-guy, but is there fuel in the tank? Twice now, I have finished using my 620, parked it in the shed and the next time it would not start. Both times the tank was empty. Must have parked it coincident with using the last bit of fuel
Green Relics
07-11-2007 05:02:17
Hi, Need to know more. Is this tractor a mag or distributor? If it's a distributor which one is it? Delco or Wico. Wico distributors have been known to be very unreliable. If it's a mag, the impulse spring may have broken, but usually they don't quit unless your running at very low rpm. They usually just won't restart. John
Hill billy
07-11-2007 15:35:53
 Re: 1951 John deere A in reply to Green Relics, 07-11-2007 05:02:17
I checked, There is spark coming off the plug wire when i jumped it to the plug. Now am i right in assuming that all the electrical is good since it runs spark all the way down to there, or am i all wet? By the way, it is a 12 volt Delco-Remy distributor.
Jon Hurley
07-11-2007 01:32:13
Had that happen before with my '51 A. the ignition switch at the time had screw on terminals and one of them had vibrated loose.
