Fuel Valve J D H
Doug Sr.
07-10-2007 21:12:27
I saw sme where they had a mod to install O rings in the fuel valve. Does anyone know where that site is? I need to repair my valve. It has hard spots in it when you turn it even with the nut off. I may not use the rings but would like to know where I saw it. Thanks guys. Yea I know santa should bring me a book. Doug
Doug Sr.
07-11-2007 08:10:57
 Re: Fuel Valve J D H in reply to Doug Sr., 07-10-2007 21:12:27
Thanks guys.
Doug
F-I-T
07-11-2007 08:10:36
Doug:
The o-ring fix has been discussed for a number of years here. If you search a bit in the archives I'm sure you'll find it described 5 or 6 years ago at least.
What I did on my last one was to chuck the plug by the shaft in my drill press, apply some Clover 0000 grease-based lapping compound, then I slowly raised the housing by hand, up to it at the slowest speed, moving it up and into engagement from time to time so the trash could clear and to apply another dab of compound. This will go a long way in improving the fit of the two pieces. They will be formed together to within millionths.
If you have no where else to turn, you can try cutting in two grooves so that they miss any ports. On a particular troublesome valve I even turned in a groove on the face of the plug where the shaft is, about midway between the shaft and the perimeter, and placed an o-ring in there to replace the packing. When you tighten the cap nut, the o-ring seals the shaft area. A square -cut seal would work as well It's been dry for a long time now.
Here's a rudimentary sketch of what I'm talking about:
third party image
P Browning
07-11-2007 04:29:30
No -- It is not in the Book. Check out the JD-H Restoration Site (below). And once you get there, look left. Scroll down to FUEL SYSTEMS for the item you are seeking. (PatB)
Mike M
07-11-2007 04:27:45
You saw it in that book and/or on the web site you and Santa have been avoiding.
Steve Crum
07-10-2007 21:24:39
I turned .010" off the small end of the valve plug, then hand lapped the plug in the valve housing with 1000 grit lapping compound. Then I replaced the packing with a strip of Goretex steam line gasket cord. No leakage problems after that. Your results may vary.
