G/MAN
07-11-2007 16:02:31
Re: 466 diesel to gas in reply to weeze, 07-10-2007 18:41:53
I don't believe Deere actually ever built a 6466 gas-burner, although I could be wrong. I've never seen one and there is no mention of one in Deere's parts program. As far as I know, the last 400-series gas-burner would have been the 6404 that was used in the rare 4230 and 4430 gasoline tractors. I supposed it's possible that someone used a Deere 6466 diesel short-block and modified it for spark-ignition, as a gasoline cylinder-head from one of those 404s would bolt right on, though. I see a couple of options, neither of which would require a computer or the installation of a ECU-type computer or any position sensors - the position of the camshaft is never going to remove in relation to the position of the crankshaft for one thing, and for another neither the camshaft or crankshaft are going to have a reluctor wheel or gear for a position sensor to read off of. The easiest and probably the cheapest - as in not requiring modifying the block itself - would be to use a simple crank-trigger ignition system, such as those made by MSD and other automotive performance ignition parts manufacturers. The sensor wheel could probably be installed on the damper relatively easily, and a bracket could be fabbed to mount the sensor, used in conjunction with an ignition box and a few other components, it would be pretty much a bolt-on deal, and would provide the most accurate timing by far, as the harmonics and "play" in the timing gears would never be a factory. The other possibility, if you're using an earlier 466 with the cam-driven oil pump, would be to machine the block to accept a distributor located right above the oil pump drive gear - pretty much just like on a gasoline 4020 engine, etc. Were it me and as long as it's legal for wherever you want to pull, I'd go with the crank-trigger - more accurate, more performance potential, no need to completely disassemble the engine for machining, no machining costs, etc.
