2 annoying problems on a 520
R Davis
07-10-2007 08:41:25
As I get older, problems that I've lived with for a long time are starting to annoy me. I've had my 520 for over 20 years it's used 2-3 times a week, sometimes more sometimes less probably put about 100+ hrs on it a year.
Problem 1 After about 10 hrs, anytime that I'm running with the clutch side down hill (I live in the Blue Ridge Mtns) I get sprayed with trans oil. When I drain the 1st red. cover I get 3-4 gal of trans oil so I just dump it back in the trans. And I'm good for a while. A couple years ago I figured I'd remove the 1st gear cover and probably find a plugged return oil hole. The hole is quite large about size of a 50 cent piece it was clear. Nothing looked out of sorts that rinky-dink collector that looks like 2 halfs of a ice cream cone seemed OK. So can't figure out what it could be.
Problem 2 The throttle rod is constantly occilating back and forth. Which causes the engine to lop it get real bad when pulling hard and when using a bush hog which puts a real strain on the gears of the PTO drive. I thought it was the gov. pulled it apart things were OK nothing bent or damaged. While having the gov to throttle rod off I noticed while holding the thorttle I could feel it shaking back and forth the faster the engine ran the faster it would shake. I was thinking that there might be a hole rusted between the exh and intake manifold but, it run really good starts easy, doesn't miss idles smooth. So don't think it's that. Any suggestions. Thanks Rich Davis 540.463.6777
jeep65
07-10-2007 14:53:01
 Re: 2 annoying problems on a 520 in reply to R Davis, 07-10-2007 08:41:25
I just bought a 520 a while back and my throttle had this problem a little. I think your problem may be worn throttle shaft. I rebuilt my carb put in new throttle shaft and bushing and problem went away.
Don
R Davis
07-10-2007 14:23:33
In addition the engine oil level is fine is isn't dropping
and I didn't over fill the trans and only put a qt back in the gear cover.
the carb problem hasn't anything to do with the linkage the linkage will be completely disconnected and the throttle on the carb will try and occiliate when holding it you can feel it pulsating.
machinery-man
07-10-2007 10:12:25
Sounds like your seal has failed at the crankshaft allowing oil to go into the transmission and overfill. Keep a check on engine oil and see if you're loosing any. Also fluid can go from the lift into the transmission.
You definitely have too much there now.
Chris in MD
07-10-2007 09:28:32
Are you sure you're not putting TOO much tranny oil in it? Seems to me like to only way fluid could get that high in the reduction cover is if you got too high in the tranny!
As for your surging problems, if you have a service manual, it would tell you that the throttle to governor linkage needs to be adjusted... i don't have my book handy, so i forget the adjustment.
