730 puller
buickanddeere
07-10-2007 07:35:48
Three main factors influence a tractors ability to pull. #1 traction, #2 traction and #3 traction. Those who get HP on the brain have been watching too much of the unlimited class pulling. As long as she will spin out in 1st gear don't worry about HP. Better yet ,few things look better than the look on the competitions faces as an obviously stock two cylinder labours along in 1st gear and into 1st,2nd or 3rd place. And the competition's "stock" tractor doesn't pull as far. As for octane. With the stock engine, filling the tank with 116octane Cam II race gas will decrease the HP. Tire pressure,height,width, bar height. bar angle, rim width and number of plies will make or break a pull. The hitch has to be at max legal height. The weights moved fore or aft along with lengthening or shortening the drawbar. The front wheels must be just off the ground as she spins out. Stand around and watch/listen to the differences between similar/same model tractors. Where a few pull well and the others get stopped at mid track. HP from an 730 gasser? From a stock displacement engine at 10% over rated rpms. Maybe 75-80HP if built with no limit to the $$$ spent.
