'75-830 3 cyl. I did it
Michael Sheik
07-10-2007 05:09:42
I know everyone told me to run from it but I sold my 9N and loader for 4000.00 and bought the 830 yesterday. Got it home last night and washed it all up inspected it good and drove it around a little. That is really a sweet little tractor. I don't think it is nearly in as bad a shape as I represented it in my post last week.
The leak in the brake line on R. side is due to it rubbing on another line and I can fix that. The tach not working is the cable and the previous owner had put an aftermarket tach on the dash panel so the two added together is 3000 hours. The left shifter lever spinning is a little roll pin and not hard to fix but have to pull the plate off to expose top of transmission to get that roll pin replaced. Trans fluid looks good so assuming the brakes are ok. I got all the filters and the steering drag link from JD for 167.00. A question:
1) With the trans/rearend fluid ok(no particles) and thus assuming brake bands not disintegrated, the left rear seems to have a very slight drag when rolling to a stop. This is very, very slight and was wandering if there is an adjustment or is it maybe the valve body on the foot pedal not fully releasing? Maybe it is not even the brake.
MH
07-10-2007 12:24:24
 Re: '75-830 3 cyl. I did it in reply to Michael Sheik, 07-10-2007 05:09:42
Sounds like you have it under control. I don't know if bleeding the breaks would help, or it could be a sticky valve at the pedals...Post some pictures it sometime. We have a 1020 & really like it, I think they are very similar.
Matthew
machinery-man
07-10-2007 11:27:15
it"s hard to keep up the numbers but the 830 is similar to the 1020...believe the 830 is German made...anyway you"ve come from the forest into the sunlight. How"d you get the $4000 on the 2N? What a sale... I can"t say on the rear end..you might jack up and see if any difference...maybe you"re tires are loaded and this is what you"re feeling....
Michael Sheik
07-10-2007 12:00:53
 Re: '75-830 3 cyl. I did it in reply to machinery-man, 07-10-2007 11:27:15
Yes indeed! The tires are loaded. I knew that when I bought it and really didn't like it but not a deal stopper. I know in the near future I will have to breakdown the left rear and put in a steel patch approx. 3 inches diameter where the stem is. I think I will also have the tire guy suck the fluid out of the other one at that time and put cast weights on her.
As far as the 4000 for the 9N, I figured I could always come down but after over 30 people looked at it within the 3 day timeframe it was setting out, I knew I was solid on the 4000.00 and afternoon of the third day it was sold. You are correct on seeing the light and darn glad it is gone!
Mike M
07-10-2007 12:08:18
 Re: '75-830 3 cyl. I did it in reply to Michael Sheik, 07-10-2007 12:00:53
Holly Cow ! 30 people in 3 days !!!
Where you at I want to consign some stuff too sell.
Michael Sheik
07-10-2007 12:11:11
 Re: '75-830 3 cyl. I did it in reply to Mike M, 07-10-2007 12:08:18
Okeene, Oklahoma - approx. 90 miles northwest of Oklahoma City.
Mike M
07-10-2007 12:30:44
 Re: '75-830 3 cyl. I did it in reply to Michael Sheik, 07-10-2007 12:11:11
I think the freight from Ohio to you would be SKY HIGH !
Mike M
07-10-2007 06:23:40
Well you can't go wrong since you got $4,000 out of an 9N !!!!!
Make sure you pull out the suction screen in the bottom of the tranny it should go crosswise and be behind a large plug. Hopefully you got a book with it as it should show this.
Michael Sheik
07-10-2007 06:42:34
 Re: '75-830 3 cyl. I did it in reply to Mike M, 07-10-2007 06:23:40
I have the book on order. Should be here this week.
Anybody have an answer to my question?
Mike M
07-10-2007 07:03:58
 Re: '75-830 3 cyl. I did it in reply to Michael Sheik, 07-10-2007 06:42:34
Could be normal drag from the rear end and gears ? I guess you can jack it up and turn each wheel seperate and see if they feel the same. Those axle bearings have preload on them so you may get some drag. Won't hurt to lube the pedal piviots and even bleed the brakes.
