2010 hydraulic problems
RLH
07-09-2007 07:23:19
2010 indrustrial utility gas 3pt/power steering quit working .it has a front pump that runs the loader that works great where is the other pump ? how doI check it ? can I plumb the front pump into the back system? thanks for the help
msb
07-09-2007 21:16:57
 Re: 2010 hydraulic problems in reply to RLH, 07-09-2007 07:23:19
Have you cleaned the transmission filter? That is the first place to start. Three capscrews on the right side of the transmission case hold the cover in place.. Drain the transmission oil out first.
swagbanker
09-15-2007 18:03:28
 Re: 2010 hydraulic problems in reply to msb, 07-09-2007 21:16:57
where is the filter at. It is a screen or a filter? I just bought a 2010 that lifted my shredder fine, up and down. used about 2 hours and would not lift, let tractor die, and sit a few mintues, lift works fine, but same old story after a few minutes of use..My tractor has a bolt head by right foot, that is where the j.d. house told me to check the fluid..
Thanks
Andrew
RLH
07-10-2007 02:16:11
I havent done anything yet it stoped all of a sudden I supect pump drive shaft maby
msb
07-10-2007 05:44:56
 Re: 2010 hydraulic problems in reply to RLH, 07-10-2007 02:16:11
Check to see if the pump disconnect has gotten moved. Its on the left side near the clutch pedal.
