Help me gain some weight (cast iron!)
WeirdDeere
07-09-2007 00:25:40
I need to put my rowcrop 70D on a weight gain program, about 600 pounds. I need weight for plowing (too light, no traction!), and I'd like to get up to 8500 pounds for a local antique pull. The tractor is 7850 pounds now, and I'm not going to remove stuff to get it down to 7500...I want to USE it!
But I can't remember the part number for the cast iron weights? And I'd like to know how much each one weighs, so I know how many to look for?
I hate asking value questions...but how much do you usually pay per weight?
As an option, maybe I'll just put some concrete blocks in my pockets when I pull?
Thanks,
Brandon
Richie Osgood
07-09-2007 19:41:19
 Re: Help me gain some weight (cast iron!) in reply to WeirdDeere, 07-09-2007 00:25:40
I could not find any John Deere weights in my area. ( Maine ) I could find a few farmall a, b, and bn weights. I built a adapter plate and use ready rod to bolt them on. It was easy. I paid about $125.00 per set. They are 140 pounds each.
BUTCH GA.
07-09-2007 04:32:30
you can gain a lot of weight by adding water to your back tires. water is 8 pounds to the gallon. if you live where it's cold you'll need to add calicum to keep from freezing when you fill them have the valve stem at the top and only fill to the top of the rim. leave a air space and run about 8 to 10 pound of air.
WeirdDeere
07-09-2007 10:09:49
 Re: Help me gain some weight (cast iron!) in reply to BUTCH GA., 07-09-2007 04:32:30
Thanks for the suggestion, but I should have mentioned that I don't want calcium. In fact, I had the rears pumped out last year. I know there are many arguments that calcium is just fine if you keep an eye on the valve stems, but I've seen too many rotted rims...
Brandon
WeirdDeere
07-09-2007 10:24:49
 Re: Help me gain some weight (cast iron!) in reply to wilamayb, 07-09-2007 04:31:00
Thanks for the info! I should have been more specific, I need weight on the rear only. The wide front axle adds enough front weight!
Can I bolt the A3404R weights directly to my cast centers (no starter weights needed?)? I think I can, but I haven't paid attention at pulls or shows. I'm not too concerned about the round vs z openings...the wheels are going to stay in the same spot.
Oh, are the part numbers actually cast onto the weights? I want to make sure I can identify them!
Thanks again,
Brandon
Mike Aylward
07-09-2007 10:39:14
 Re: Help me gain some weight (cast iron!) in reply to WeirdDeere, 07-09-2007 10:24:49
Brandon, there are three different versions of the A3404R weights. The first version was used on the "R" tractors and have a round center hole. They will bolt onto your tractor but will not allow you to change the wheel tread once mounted. The second version has an oval center hole and will allow you to move your wheels if two or less weights are added. The latest, and most familiar weight is the "Z" style center hole. They weigh slightly less but allow much easier wheel tread adjustments. All three styles will have the A3404R cast into them. I assume you have the F1500R centers on your tractor so you will not need any starter weights but you will need the special bolts to mount them on your wheels. You can use regular bolts but it's sure a lot easier to use the special ones. You will also use a special bolt in the weight if you want to add more later. Hope this helps. Mike
WeirdDeere
07-09-2007 10:48:35
 Re: Help me gain some weight (cast iron!) in reply to Mike Aylward, 07-09-2007 10:39:14
Thanks Mike, that helps! And yes I have the F1500R centers.
Brandon
BLinWMi
07-10-2007 04:11:22
 Re: Help me gain some weight (cast iron!) in reply to WeirdDeere, 07-09-2007 10:48:35
The weights being discussed will bolt right on your 70, I did the exact thing to my 70 last week. Had 3 sets of weights in the corn crib and drug one out with intentions to put on my 720 standard but upon trying it, found out they will not fit the hub on 34 inch tires. I went to Deere and bought the correct bolts for about $5.25 a piece and put the set of weights on the 70. I agreee, do not care for calcium in these tractors, so some cast weight is nice to find. I now have weights on a 70, a LI, a H and an AO. I have found several sets of weights at auctions, that came off new generation tractors.
