Tim - Last thing first: The ammeter should swing to the right (+) when the battery is being charged. Just remember "+" is good; "-" is not so good! ---- Presuming your B wired up correctly, your new Walmart battery is healthy and there's not some other external electrical load that's left on (not likely on a "B"...), the battery running down is from a low current draw thru the alternator when shut down. To verify take a VOM or digital multimeter and set it to the DC milliamp range. Disconnect all the wiring at the alternator (the cable to the BAT terminal and the aux plug). Now with the battery connected and your toggle alternator control switch "off", use the meter to measure current beween each alternator terminal and it's mating wiring harness terminal. Look for the following: The #1 aux terminal should show no current whatsoever. (Any current flowing here says the external wiring is wrong.) The #2 terminal should show a vanishingly small current flow (typically a few MICROamps). A flow measured in MILLIamps says the internal regulator is "leaky" and needs replacement. You can either replace the regulator yourself ($12 or so) or swap in a fresh alternator. Finally current flowing at the BAT terminal should be on the order of a few milliamps. Anything greater than 10 - 15 milliamps means there's a problem with the alternator's internal rectifier bridge. Cheapest fix is probably replace the alternator with a fresh rebuilt unit. ---- Hope this helps...
