JD 650 Electrical Troubles
Bert in OR
07-08-2007 15:25:02
I've got an '81 650 w/ 1300+ hrs on it. Am trying to track down a starting problem. Started out the starter wouldn't turn over. Could hear a solenoid click but that was it.. Battery read 12.39 volts. Cables are new two years ago. Took the starter off and cleaned/checked everything and it worked/tested fine. Put it back together and still just a click.. Hooked the ford diesel truck up to it and it started and ran fine.. Unhooked the ford, let it run 40 mins and shut it off.. NO RESTART..
Put a new battery in this am. Turned the key switch and the battery/oil lights were red while the glow plug warmed. Turned the key to start and the starter solenoid clicked and that was it. I now don't have any dash lights at glow plug warm up or in start position, they work in the on position. None of the head or tail or flasher lights work either.
Did the manual test of the voltage regulator w/ my little car ohm meter, it only has 20K and 2k settings, not a 10 like the book wants. Everything I tested read a 1; No Continuity according to the book. Can the whole thing short out?
Anyway I'm looking for some pointers or advise before I consult the local dealer because I just can't afford a $1K service call right now.. Voltage Regulator, switch or back to the starter?
thnx,
Bert
Bert in OR
07-08-2007 18:27:27
 Re: JD 650 Electrical Troubles in reply to Bert in OR, 07-08-2007 15:25:02
A little more info....
I hook the old ford diesel truck up to it w/ battery cables and all the lights worked and it turned over about 1/2 a revolution each time I turned the key to start..
Tell me if I'm wrong here but it's gotta be the battery cables or the starter solenoid? Disconnected and removed both battery cables. Hooked jumper cables to the battery and tractor frame.. touched the positive cable to the small starter tang (not the one the cable goes to) and the starter engaged very well but didn't turn..
gotta be the solenoid ????? Or have the whole starter rebuilt by the yanmar guys down by Salem?
thnx,
B
Maark
07-08-2007 17:00:07
Check and clean the ground conections, both at the battery and where it grounds at the tractor frame,also the positive connections.
