Gas in Motor Oil on 630!
EH in SC
07-08-2007 09:16:40
Before starting tractor yesterday, I checked all fluids and noticed that the crankcase oil seemed a bit "thin". Then smelled it and sure nuff smelled like gasoline. Just changed oil and filter last weekend and old oil seemed to be OK, but dark. I have the oil pressure sensitive fuel shut off on this tractor (that is what it came with), and I check it almost every time I shut the tractor down, because I've heard about them not being totally reliable. Even though it is not "original" should I put a cut-off in the fuel line? Also, are there another places I should look for the problem first? Thanks a bunch for all your guys help!
EH in SC
07-08-2007 15:56:54
 Re: Gas in Motor Oil on 630! in reply to EH in SC, 07-08-2007 09:16:40
Thanks very much guys! I will follow the advice and get a rebuild kit for the fuel shut off assembly. While at it, I will replace all the "replaceable" items at the sediment bowl as well. Unless you guys lead me to rebuild the carb, I would as soon not tear into it as the tractor runs fine, just maybe a tad rich. Still wondering if I should add a manual shut off on the carb side of the sediment bowl. Is this a waste of time and money, or cheap insurance against this happening again? Frank is right on about the $ for more oil and filter, not to mention this takes more time away from play with my 630! Thanks so much I am finding this site to be of huge benefit and appreciate all of you "teachers"!
Maark
07-08-2007 10:20:52
You need to rebuild the oil pressure fuel cutoff assy. The diaphragms go bad, gas leaks back through the oil lines and into the crankcase.
F-I-T
07-08-2007 11:21:30
 Re: Gas in Motor Oil on 630! in reply to Maark, 07-08-2007 10:20:52
I thought he said he had the auto-fuel shut-off not installed on the tractor.
If fuel leaks into the crankcase, it has to get past the sediment bowl shut-off if it was cranked shut, then it has to leak past the float needle valve/seat in the carburetor. I would not see the need to add yet another valve when fixing a faulty needle valve/seat or sediment bowl valve or both, or do as Maark said and repair the auto-fuel shut-off valve would do the trick.
Shut the sediment bowl valve, open the carburetor bowl drain and see if it shuts off the flow. If so, look into the needle valve/seat, or possibly a sagging/leaking/mis-adjusted float.
One oil change and lost gasoline these days will buy a lot of parts.
Frank
wilamayb
07-08-2007 12:23:24
 Re: Gas in Motor Oil on 630! in reply to F-I-T, 07-08-2007 11:21:30
Come on now Frank... Read it again. LOL
As for the shut off:
These gentlemen have given you the possibilites. Either the fuel is entering the crankcase through the valve into the crankcase oil or the valve is not shutting off all the way allowing the carb needle to leak it into your combusiton chanber, past the piston rings, and into the crankcase. Either way I think a rebuild of the shutoff valve would fix your problems. I think Deere still offers the kit for rebuild.
Be sure that there are not getting foreign pieces of material in your fuel tank as they will prevent the valve from being able to shut if a chunk gets lodged (may be your problem now). If anyone has removed the screen above your sediment bowl you might look into replacing it to keep that junk out of the valve.
If you want to take the time and spend the money you could do as Frank said and check out that carb needle and float level setting. Its a double safety. Mother Deere knew from the letter series tractors that it was almost impossible to keep a needle from seeping so they installed this oil pressure controlled gas shutoff. If you install a new needle and seat I would spend the $ and get the real deal from Robert's carb, or any other premium kit. Even with the expensive needle and seat you may have to use a little lapping cmpd to get it not to leak.
Farmer Jack
07-10-2007 09:48:02
 Re: Gas in Motor Oil on 630! in reply to wilamayb, 07-08-2007 12:23:24
What's the best way to make sure the float needle seats well to shut off the flow of fuel? I installed the "rubber" tipped needle from Robert's Carb repair, but I am not sure if that has totally fixed the fuel problem I have.
EH in SC
07-09-2007 10:57:33
Thanks for all the good input! I am still curious if I should put a manual fuel shut-off between the sediment bowl and carb or if this is a waste of time? It wouldn't take many more unscheduled oil changes to pay for it! I know this is not "original" but is this a common practice among the two cylinder group? Thank you, Ed
F-I-T
07-08-2007 12:27:15
I mis-read it. Sorry.
