How critical oil pan bolts to clutch housing 4020?
nylon
07-07-2007 23:53:48
My two very bottom 1/2 inch oil pan bolts are striped. I think I am going to have to get the oil pan off to tap in the helicoils suggested by you guys. Wondering which bolts to tighten first when it goes back together. The 2 front 1/2 bolts finger snug then torque the clutch housing 1/2 inch bolts..then torque the 2 front pan 1/2 inchers.....then last the 3/8s bolts?
What is best tool to use to put in helicoil? Guy at napa says use a drill. Thought you wanted to tap in new threads kinda slow like using a tap so all the new threads dont get pulled out. Which is better method in clutch housing cast metal....helicoil or tap larger hole?
Roy in georgia
07-08-2007 18:46:45
 Re: How critical oil pan bolts to clutch housing 4020? in reply to nylon, 07-07-2007 23:53:48
you get that helicoil installed yet? I saw an old friend of mine make a jig for a right angle drill out of a piece of pipe or 2 pieces of steel with a hole drilled in it for holding a drill bit some what true is tight places. it seemed to work well for him he also used it to put helicoils in heads and blocks I saw him put 1 in a main bearing bolt hole in a 350 chevy that I built that went over 100000 miles so if your other question is are they strong I say "NO DOUBT" Roy
Bob
07-08-2007 03:50:42
Toward the front of the oil pan at each side is a special screw, with a tapered head, that aligns the oil pan.
Third Party Image
The Heli-coil set will specify what EXACT drill bit to use to prepare the hole for the SPECIAL tap that comes with the kit. (Heli-coils require the use of a special "in-betweeen size" tap for each thread size.)
Nylon
07-08-2007 08:52:21
 Re: How critical oil pan bolts to clutch housing 4020? in reply to Bob, 07-08-2007 03:50:42
Thx Bob,
So dont mix those 2 bolts up with the other 6 at the rear!
Appreciated,
John
