4020 and radiator again
Nylon
07-07-2007 23:43:35
Book says remove radiator. doesnt say how. I am looking at this thing and don't see how I can get it out. I would like to only remove the shroud and sand blast it. So figured I would have to loosen radiator but that will only bump forward 3/4 of an inch before hitting air cleaner cannister. Only way assembly can come out is if pully on water pump can come off. Just removing the fan blades still leaves pully sticking out too far to clear shroud.
Thinking only way to get shroud out is to:
Unbolt shroud from radiator, pull it back against engine and water pump as tight as it can go, slip radiator out the side...left side...and then get the shroud out. Really dont want to drain cooling to get the shroud out but looks like only way if at all.
Anyone have a no-drain way to get the shroud out?
Gerald J.
07-08-2007 09:16:29
 Re: 4020 and radiator again in reply to Nylon, 07-07-2007 23:43:35
The water pump shaft sticks through the fan blade so removing the fan blade and the water pump pulley (and there isn't room to remove the water pump pulley with the radiator in place) won't gain you the room you need. Maybe if you remove the water pump (it will come out the right side), the shroud might come out the left. Perhaps its time to scrape, sand, and paint in place. Maybe doing that by hand is less total work than taking the shroud out for sand blasting.
Gerald J.
Nylon
07-08-2007 15:06:38
 Re: 4020 and radiator again in reply to Gerald J., 07-08-2007 09:16:29
Seriously considered that. But there are about 3 layers of bad paint jobs on it already. Don't want to do it but everything else looks so good sandblasted without paint already that I would regret it. I know I should just use 4020s and discard them but I cant....I use them really not all that hard. I know I will probably have this 4020 till I croak and at the moment Im 42. So optomisticly..for a while anyway. Plus 4020 was main farm tractor when I was 0-18 years old. Had a jd 60 for a while and hated the hand clutch stuff. Got the nostalgia bug for a new gen...never was around 2 popers much.
msb
07-08-2007 05:06:05
You got it.
" Unbolt shroud from radiator, pull it back against engine and water pump as tight as it can go, slip radiator out the side...left side...and then get the shroud out. Really dont want to drain cooling to get the shroud out but looks like only way if at all."
Nylon
07-08-2007 08:55:55
 Re: 4020 and radiator again in reply to msb, 07-08-2007 05:06:05
MSB,
If you get a chance, could you shoot me an e mail....
[email protected]
Thanks,
John
