1953 AR gets hot and has low oil pressure
JOE-ILLINOIS
07-07-2007 19:17:25
I just bought a AR, after it runs for 45 minutes the temp goes to 200+,should I start at the radiator,it has a water pump, a neighbor told me the thermostat could be stuck but I did not think it had one, it carries low oil pressure could wore bearings cause high temp, tried to turn up pressure seems to be turned all the way up. oil was thin so I flushed and put in 15w40, would 40wt be better, did not have a new filter, used old one for now would that make a difference, thanks joe
