'51 B sputters at higher engine speeds
ol guy
07-07-2007 14:23:37
This newly restored tractor starts perfectly and idles o.k., but with advancing the throttle it sputters, mis-fires and has very little power. Carb was rebuilt by an "expert".(Has Delco dist. ignition). Assuming it is fuel-related (and not ignition) what are the likely culprits?? Incorrect float level, for example ? Tank was cleaned and sealed and sed bulb looks o.k.
ol guy
07-07-2007 19:49:28
 Re: '51 B sputters at higher engine speeds in reply to ol guy, 07-07-2007 14:23:37
Many thanks for all the constructive/informative replies to my above questions. I have printed off the carb info from the JD H restoration site, and it"s very helpful. Time to go to work!! Thanks again.
Mike M
07-07-2007 18:47:33
Did you adjust the carb. for YOUR tractor ?????
Try opening up the load needle some first.
ol guy
07-07-2007 19:39:26
 Re: '51 B sputters at higher engine speeds in reply to Mike M, 07-07-2007 18:47:33
YES! Over and over again with the idle and load needles in various amounts of "Openness". I could not make it run decent over 1/2 throttle at any load or idle setting.
Mike M
07-08-2007 06:19:44
 Re: '51 B sputters at higher engine speeds in reply to ol guy, 07-07-2007 19:39:26
Why would you as-u-me that it is in the carb. ? ( potty filter won't let it spell right ) Do that no wrench carb. test Pat mentions as it should tell you if the passages are plugged or not.
Ignitions and spark plugs can cause some funny stuff to happen that often makes one think it is fuel related.
And for sure double check for real good fuel flow from the tank to carb. and a piece of clear tubing hooked to the carb. drain and held up along the side will show you the true fuel level even while running.. I'm thinking it should be around 3/4" from the top of the bowl.
P Browning
07-07-2007 15:53:36
ol guy -- There is a quick no-wrench test you can perform on your carburetor to be found here on line. Go to the JD-H Restoration Site (below) and once there, look left. Scroll down to CARBURETORS. At the end of that 9-page piece you will see the test for the two pathways of your carburetor, IDLE & LOAD. And - yes, the test will work on your B! (PatB)
F-I-T
07-07-2007 14:44:59
Does it happen when you advance the throttle rapidly toward WOT? If so, the aceleration sump on the outside of the central brass nozzle probably is clogged or the sump is filled with rust, dirt and various debris. If it just does not run well at WOT, it could be in the idle circuit. Does it try to run decent if you apply a bit of load? If so the load circuit is probably working because the load circuit is larger and as the throttle butterfly opens further the idle circuit falls out of the mix and the load takes over. If it sputters and maybe gets even worse under load, the nyou probably have a problem in the load side, too.
I'd be calling my "expert" right after I verified that my fuel tank and lines were not responsible for filling his rebuild job with dirt.
Frank
ol guy
07-07-2007 19:33:43
 Re: '51 B sputters at higher engine speeds in reply to F-I-T, 07-07-2007 14:44:59
If you advance the throttle slowly, the sputtering/uneven running is not too bad, The faster you advance the throttle, the worse it gets. Regardless of how both the idle and load needles are adjusted, it simply will not run right at full throttle.
jk
07-07-2007 17:31:27
since were on the topic of B carbies, i have a 45 B. the guy i got it from (after he bought it fro my dad and my dad told him) the he needed to "rebuild" or tear down and clean the "power valve" my question is, where the BLEEP is the the "power valve"? i beleave it to be "all fuel" or whatever the JD equal was to that, as it has one fuel tank for gasoline and one for kerosene. thanks
