'40 A carb troubles?
Farmall MD
07-07-2007 11:52:36
Fired up the A today. Couldn't hand start it, so I pulled it. Didn't fire up too bad. Problem is that when it's running, it seems to be hunting(surging). It won't run smooth like it did last time I ran it. Runs good under a load though.
Last time it was run was about 3 weeks ago. Carb was just redone about 2 months ago. No water or dirt is in the sediment bowl. Could it be possible to go thru carb again? Or am I looking in the wrong area and spark could be a problem?
Doug N
Dorothy Stickler
07-07-2007 14:08:27
 Re: '40 A carb troubles? in reply to Farmall MD, 07-07-2007 11:52:36
Check the length of the throttle rod. It must be about 1/2 hole longer than the nominal distance from the governor to the carb both in the max speed position.
F-I-T
07-07-2007 14:37:38
 Re: '40 A carb troubles? in reply to Dorothy Stickler, 07-07-2007 14:08:27
you mean 1/2 hole SHORTER....pulling against the throttle spring to force the rod to connect that 1/2 hole short gives pre-load to the governor shaft to remove any play in the governor guts so it doesn't jump around. But I'm not sure that is the problem. Sounds like dirt in an idle circuit, rebuilt carburetor or not. The rod/governor linkage didn't just jump out of adjustment.
Frank
Farmall MD
07-07-2007 16:14:13
 Re: '40 A carb troubles? in reply to F-I-T, 07-07-2007 14:37:38
That's what I was thinkin, rod adjustment just doesn't pop out overnight. I thought it might have been dirt too, just wanted to make sure. Guess I'll pop it off tommorrow and give it a go over. And yes, when I rebuilt it a while ago, I even got the famous "mystery hole". It was plugged completely shut. Doug N
