'44 John Deere Model A carb
Don E. Foster
07-07-2007 07:56:54
My '44 model A has been flooding when starting without choking, bad. I removed the carb and tried to get the nozzle out but it is really stuck. Soaked it in Kroil over night of no avail. So..... .....I just blew the hell out of the nozzle and tried again. No luck. So, I start it on the belt and it runs OK.
1. How to get the nozzle out without upsetting it?
2. What is the problem?
Thanks
F-I-T
07-07-2007 09:11:18
 Re: '44 John Deere Model A carb in reply to Don E. Foster, 07-07-2007 07:56:54
Don:
You say it starts right and runs all right when started from the belt? If it's magneto ignition, maybe the impulse spring is soft or broken, so it doesn't generate sufficient spark, and if it doesn't fire, the plugs will eventually get wet, whether it is choking for air or not, and you can mistake that for flooding. "Flooding" for me is when an engine ingests so much fuel that it overwhelms the spark, the plug fouls, and there you are.
If it fires right up and runs right from the belt, which is spinning it fast enough to overcome the impulse spring, I'd check the spark at cranking speed to see if it is sufficient. The nozzle almost always has some debris trapped inside, but I don't think it would cause any of your flooding symptoms. Float height, a leaking needle/seat would be the two most probable causes.
While you're at it, take a look at the fuel flow out through the sediment bowl, and make sure you have a pencil sized stream of fuel out of the carburetor drain valve for at least thrity seconds. Also shine a light in the tank and look for a chunk of stuff that might come and go, sometimes blocking flow. That's not necessarily germane to your problem, but I always start at the tank and work towards the smaller passages in the carburetor. You never what else you might find.
Frank
P Browning
07-07-2007 08:37:14
Don -- It sounds like more than a single problem. But I think it safe to say that the carburetor is common to all. As for the flooding, you could have a bad float, a wrong float setting, or a float needle valve that isn't closing. The valve not closing is many times due to debris in the fuel system. And so I think a total flush and a clean supply of fresh fuel would be my starting point.
It goes without saying here that your ignition system is perking okay. You have to deal with the easy-to-check things first.
One other thing that comes to mind here is the air-in for your carburetor. If dirt daubers have made a home in your air stack, it is kind of like operating your tractor with the choke closed. Drop the oil cup from the air cleaner and see if the engine runs differently. Some will advise you here (rather) to open up the joint between the carburetor and air-inlet elbow for this test because they claim it is safer -- less chance a backfire could ignite fumes in the air cleaner mesh.
As for having torn into the carburetor already -- that is if you indeed have -- and need to get the fuel nozzle out, see the following YTMag thread on the issue.
Link
