41 B Flat Spoke Wheels
JD Gimpl
07-06-2007 22:17:52
Hello,
I just picked up a 41B with the flat spoke wheels. They a rusted out in several places, can I cut and weld in new pieces?
Anyone know where I can get an old wheel to cut on?
Thanks JD Gimpl.
JD Gimpl
07-07-2007 20:58:05
 Re: 41 B Flat Spoke Wheels in reply to JD Gimpl, 07-06-2007 22:17:52
Sorry, I meant the wheel is rusted out not the flat bar.
JD Gimpl
Maark
07-07-2007 11:27:34
Guys, I'll bet he means the rims are rusted out, not the spokes..
P Browning
07-07-2007 04:52:27
Just been there -- done that! The spoke stock is 3/8 x 1-1/2 inches. This is very common bar stock available from any welding operation, or through one. (PatB)
Jim in Ma.
07-07-2007 06:43:41
 Re: 41 B Flat Spoke Wheels in reply to P Browning, 07-07-2007 04:52:27
where are you?
I have 2 flat 41s one is good and the other has a broken center hub - I'm not sure what to do with them. I live North of Boston. Jim
Gary from Muleshoe
07-07-2007 04:26:01
If it were me I would just find the right size flat stock and cut out the entire bad spoke and weld in new. Finding old wheels to use as parts will be hard to do as most that are good for parts are in use.
CalJim
07-06-2007 22:29:54
I would think it makes a difference if they are factory flats or cutoffs. If they are cutoffs you could use steel flatbar cut to size. Either way it will probably be hard to find wheels for "parts". CalJim
