7000 Planter Question
Tom in Michigan
07-06-2007 18:48:40
The marker coulters (new) didn't penetrate very deep making it difficult to follow - especially in the alfalfa. I have had them dished in and dished out with no noticeable difference. Added some wieght which had positve results, but still difficult to see. Any suggestions? Tom
andy r
07-09-2007 20:01:00
 Re: 7000 Planter Question in reply to Tom in Michigan, 07-06-2007 18:48:40
I purchased two small notched blades at a farm store. Then I took two salvaged marker disks with the bearings attached, centered the new notched blades on the front side of the straight disks and welded them together. Probably used six to eight - two inch welds to hold them together. Since I do not have depth bands I actually had to adjust (straighten) the angle of the blade so it won't be so aggressive. I would make sure the bearings are in good shape before you do this as this is certainly harder on them. It has worked well for me.
Tom in Michigan
07-08-2007 16:18:18
All of your comments and suggestions are appreciated. Thank you. Tom
James22
07-07-2007 20:57:33
As MSB indicated notched blades work best in notill. I looked at converting from smooth to notched using all JD parts and it was pretty expensive, over $600. Bought complete Yetter notched blade kits from Sloan Express for around $80. Easily bolted up and worked great for a lot less money.
James22
07-08-2007 09:39:19
 Re: 7000 Planter Question in reply to James22, 07-07-2007 20:57:33
I bought mine a couple of years ago and the price has gone up substantially. The new catalog shows they are $249/pair with the depth band.
Mike in Ne
07-07-2007 07:20:30
Sharpen the marker blades.
Gerald J.
07-06-2007 20:08:52
third party image
I had problems with mine so I took off the angle brackets and smashed them back square with my hydraulic press then I had some 1/2" bars welded to keep them square, diagonal braces. They marked no till ground for me fine this year because they stood up. The marks were almost deep enough to self guide the tractor front wheels. (on a 4 row narrow the marker can't be shortened enough to get to the middle of the tractor and I like it under the tractor wheel, its far more precise).
Gerald J.
msb
07-06-2007 20:08:39
Notched blades penetrate much better.Try a Kinze dealer if Deere doesn't sell them.
