That M/S uses a large area diaphragm to run the accelerator pump. I suspect its often at fault when that carburetor messes up and isn't often replaced. Could also be ball check valves in that internal plumbing. Its such a difficult carburetor to tune that there was a Deere service bulletin in the early 70s suggesting it be replaced by the Zenith that was sometimes shipped. My 4020 shop manual has a large chapter about that carburetor. Be sure the intake to the carburetor is open. I had a trouble with the Zenith running very rich, especially at idle and I found several things: 1. the choke wire wasn't opening the choke all the way. The sheath wasn't bolted down near the carburetor where it should have been. 2. It may be warm enough to do without carburetor heat, but the manual calls for heat up beyond 70 degrees unless working the tractor very hard. 3. The top of the Donaldson precleaner was domed down from being tightened too much and that was an intake restriction. 4. A dirty aircleaner restricts and the carbureted engine doesn't compensate like a fuel inject engine with a mass air flow sensor, the carburetor just runs rich. 5. Nests in the intake pipes also can restrict the air flow. 6. The needle and seat may be worn. Mine was. The day I picked it up at the Deere store, I wandered into the shop where their gas engine expert was and asked about that rich running and his reply was, "Unless you have replaced the float needle and seat, I won't talk to you, but I do have ways to cure its problems." I had the new needle and seat in a sack in my hand so I went to the barn and put them in and did all these other things. Cut my fuel consumption from 400 to 250 gallons a year doing the same amount of work. And its lean enough it starts faster, even when warm, with a pull on the choke. I did not turn any mixture screws, just fixed its ills. Its sure worth checking the float too, but needle and seat are crucial. They got worn from vibration. I also have copper wires, AC plugs and proper timing. All these had some effect on its running. The carbon wires were intermittant and made it buck in road gear. Gerald J.
