2020 electronic ignition
henhawk
07-06-2007 16:51:35
how difficult is the conversion from standard point ignition to the electronic ignition systems. Is there many additional parts required. Also is it that much of an improvement. I have the negative ground system.
buickanddeere
07-07-2007 05:53:29
 Re: 2020 electronic ignition in reply to henhawk, 07-06-2007 16:51:35
It might take 10-15 minutes to install the pertronix unit & their matching coil. May as well install solid core plug wires when doing the job. This would be a good time to inspect& clean the mechanical advance.Wear or sticking will ruin HP & economy. Lube lightly with something non-stick & non conductive = no graphite powder.
machinery-man
07-07-2007 04:37:47
I've done many on the 2 cylinder and wouldn't have one without electronic. Everything around us is electronic, lawnmower, tillers, chainsaws, I've wondered why the resistance on tractors. Haven't had any problems with all the plugs and it virtually doesn't matter about plugs any more, these units will fire any plug about 35,000 volts. The selling company said the only reason it couldn't be more was the original ignition cap would jump fire if higher. Really can't say enough good about these units.
John T
07-07-2007 05:52:35
 Re: 2020 electronic ignition in reply to machinery-man, 07-07-2007 04:37:47
Glad to hear of your good luck with them. Its a given no brainer they have the capacity to yield more spark gap energy for a wider hotter spark, but there is a natural reluctance to use them cuz ITS IS NOT A MOTHER DEERE ORIGINAL a purist would say (which is prefectly correct and understandable). Others dont like them cuz as I posted below if they fail youre stranded while if it was points a good point cleaning n filing can get you back to the barn.
A note concerning "firing voltage" The voltage will rise across the spark plugs gap ONLY HIGH ENOUGH to arc current across it REGARDLESS if its a stock coil and points or an electronic ignition. The voltage required to jump that gap is a function of the distance (plug gap) and the medium (compression and fuel) in which the gap exists. THEREFORE given the same conditions the stock coil and points will fire the plug AT THE SAME APPROXIMATE VOLTAGE..... ..... ..... ...
HOWEVER, the elec ignition still offers big time advantages (1) If even at the same plug gap and voltage, there can still be more heat n energy expended across the gap (thst what ignites the fuel) caused by more arcing current flow or a longer spark duration. (2) Since the elec ignition has the capacity to switch more coil current, a higher energy and higher voltage coil can be used allowing the use of a wider plug gap (the voltage may then indeed rise to 35,000 versus only 10,000 in a narrow plug gapped stock ignition), and across that wider plug gap you can get a hotter spark passing through a wider portion of fuel to better ignite the fuel.
Yhats likely more then anyone wanted to know lol but I find it interesting.
John T
John T
07-06-2007 19:29:24
You basically simply remove the points and condensor, and in their place mount a magnet over the cam and a pickup coil on the plate where the points n condensor used to be. Then one wire from the unit hooks to the coil + and another to the coil -
If youre at neg ground be sure n get a neg ground elec unit!!!!! !!!!!
To get the most bang for the buck that elec ignition has to offer, I highly recommend you replace the stock coil with a high energy high voltage coil (matched up with your elec switch) and you then usually run a wider plug gap for a wider fatter hotter spark to better ignite the fuel.
An elec ignition can generally produce much more spark gap energy then a points ignition plus you dont have the points (or condensor problems) burning n pitting and carboning up and decreasing spark energy as they age.
HOWEVER if points carbon up you can file them to get her to the shed, while if an elec switch goes belly up, youre stranded. Many elec solid state devices can last for years once they successfully burn in however.
Your tractor n money, its your choice.
John T
