Clutch problem....trouble disengaging
Randy G.
07-06-2007 14:25:18
My 1955 50"s clutch has trouble disengaging at first. Once she"s warmed up some , no problem. But until then I must apply the brakes after pulling back the hand clutch just to stop, then it releases. All was re-worked/replaced 3 years ago. Where do i start to fix the problem before I hurt something or someone. Thanks for any direction. I want to correct this a.s.a.p. Randy G.
John Van Valkenburgh
07-06-2007 15:59:46
 Re: Clutch problem....trouble disengaging in reply to Randy G., 07-06-2007 14:25:18
Randy,
It may just need the clutch pully/brake adjusted. A lot of people don't know that if the pully brake is not adjusted tight enough, such that it allows you to pull back the clutch handle too far, that the clutch will actually begin to engage again.
The first thing I'd do would be to start the tractor off in gear and then slowly pull back the clutch. You should feel it pop "out" and very shortly thereafter the pully brake should begin to engage. If the brake is worn too much and does not engage quickly enough you can pull the clutch lever back too far and it begins to engage again.
Best of luck,
John
1953 Model 50
