40W Dual TOM check valve ?
jCarroll
07-06-2007 11:38:18
My 40W twitches about every two seconds - the lift arms will drop about 1/2", and then they'll lift back, etc, etc. With no load (engine off) the arms will fully settle down in about a half hour.
The Service Manual is pretty specific that this is a leaking check valve(s) problem. My questions:
1. Can the check valves be removed for inspection/seating/replacement without tearing down any of the rest of the unit?
2. The Parts Catalog shows the valve push rod, shims, check valve, and springs as loose parts in the bore. Will these parts "fly all over the floor" when the seal is removed?
Any words to the wise?
Thanks much
Dave H
07-06-2007 18:46:27
 Re: 40W Dual TOM check valve ? in reply to jCarroll, 07-06-2007 11:38:18
JCarroll
If you solve it, please post back and let me know what it was. I am plagued with this on a 420 W. I have it set in the dual mode, draft is locked out and it still won't ease up if I pull all the slop in the linkage forward or back, and I know about the spring ont he late 420'S.
I have had mine apart for a complete ovberhaul and it still acts like yours.
You surely have the early check valves. As I recall they should just pull out. Nothing will fall inside even if it is a mess since the control valve is blocking that avenue to the inside. Obviously if it is a disaster in there something may already be inside, but I doubt it.
As I recall, the book says to make sure you install the control valves before the check valves. That is during a reassembly on a complete tear down. Without the control valve in there there will be noting to stop the check valve from extending way inside and then being damaged when one tries to put the ocntrol valve in.
Anyhow on my schedule of things to do in the next six weeks is to pull both of my check valves and if I find nothing flakey put the new springs on them that I have already bought.
Working mine surely won't help since it has about 100 hours on it doing work with a 750 pound landscape blade. At times it would be walking on the hind legs when the ripper teeth bit hard into clay.
So good luck and don't forget to post back, I will do likewise when mine gets to the front of the line and I work on it.
Dave from Ohio
07-06-2007 13:28:30
Sometimes all you need to do is adjust the load/depth control linkage that is associated with the outer lift control lever. Its a lot easier than tearing into your Touch O Matic System. It is possible that one of your control valves is not seating correctly causing your system to "jump", but a more common reason is slack in the load/depth linkage. When TsTex is talking about replacing something before you install the valve you dont have to worry unless you take your whole unit apart and remove the control valves (way on the inside). A few questions, Is your unit a dual or single touch o matic? Did this just start happening or did you adjust/work on your hydraulic system before it happened? Some of this stuff gets confusing, if you want give me an e-mail and Ill do my best to explain what I know to you. Thanks, Dave
tstex
07-06-2007 12:48:05
JC,
It has been 2-3 yrs since i completely overhauled my TOM and both my parts and service manuals are at the ranch.
I recall that taking out the check valves is not that much of an issue. However, when reinstalling them, i remember there was a very specific note that you can damage them if you install "something else" first [help me here fella's].
When you take the seal-off, just be careful and note the order...the spring is not going to go flying off, but keep you hand on the hole and be careful when pulling the valve out.
Finally, what is the history ot the TOM unit? Did this just start happening?
Have you changed the oil lately? what type of oil do you have in there?
Sometimes you really have to work the UNIT real hard to heat it up and seat the valves and it will stop the jerking...my did that too after the overhaul, and when i worked it real hard, it has worked perfect since.
Good luck and post back,
tstex
jCarroll
07-06-2007 15:07:10
 Re: Answers to ??? in reply to tstex, 07-06-2007 12:48:05
I have had this tractor about 4 or 5 years. It appears to have had some days of hard work. From my start, the 3 pt leaked down too fast, and there was a little external hydraulic leakage around the rockshaft - but all of my Dubuques do that! It's a dual TOM - I have it tied together with the control handle to the front. I use NAPA General Purpose hydraulic fluid in it. I have never had an implement on it which would have "worked" the TOM.
last year I built a parade seat for the grandkids to ride on which attaches to the 3 pt. This is when i noticed the twitch. I haven't put a wrench (yet) on any part of the TOM.
420 430 40
07-06-2007 20:02:33
 Re: Answers to ??? in reply to jCarroll, 07-06-2007 15:07:10
dave from ohio maybe on the right track the same was going on with mine , it you have it tied together the selector lever forward (pins out )inside lever pulled back and just raise and lower the outside lever only . now to check out your load linkage unpin your duel lift arms, selector lever to the rear( pins in) bring both levers to the rear ,you should have about 1 1/2 inch of free travel up and down , on the lift arms . post back let us know
jCarroll
07-09-2007 15:16:03
 Test results in reply to 420 430 40, 07-06-2007 20:02:33
I followed "430-420-40" direction, and am making progress. Just don't know if I'm going forward or backwards.
I untied the left lift arms, and put the control valve to the rear - now it has independent cylinder operation. The upper link is in the top hole (most sensitive for the 40W). I operated both control levers several times. It was 92 here today, so the oil was already warmed up. I couldn't tell much difference, so I climbed into the parade chair to give the 3-pt a little load. The twitch was still there, and then I noticed that when I shifted my weight, the 3-pt would twitch in response. That is, I could make it twitch more by jerking around than just sitting still. I could see the Load And Depth Control (LDC) rod move when i jerked the chair.
So, I moved the upper link from the upper hole to the lower hole (least sensitive) and the twitch is gone. Thus I concluded that the LDC was causing the TOM to respond to some degree,
Back to the Service Manual - I can find the procedure for adjusting the pressure spring (two nuts) on the LDC, but I cannot find any info on adjusting the rod from the LDC mechanism to the TOM quadrant. Mu intuition says there should be no slack, nor any pressure without any load - but intuition is why they write service manuals. How do you adjust the rod?
The 3-pt still settles down when the engine is OFF. Now I'm thinking that i have at least two separate problems:
a) adjustment of the LDC
b) leaky check valve(s)
Your comments are welcome.
