Question about an A Crank
730-LP
07-05-2007 20:24:58
I have a 1940 John Deere A that has a bad crank,
[not out of tractor yet]I have a good crank out of a 1949 are there any difference other than the threads on the flywheel side /thanks
Drew
07-05-2007 21:42:30
 Re: Question about an A Crank in reply to 730-LP, 07-05-2007 20:24:58
The splines are a slightly different diameter. You may be able to do enough rigging to make it work, but I would recommend getting a A2360R 6.750" stroke out of an early A instead of messing with the later one.
cole in mo.
07-05-2007 20:41:00
I take that back, stroke should be the same, 39 had the shorter stroke, but for some reason I think you will need the crank from models with the starter on top.
cole in mo.
07-05-2007 20:36:00
It's got a 1/4 inch more stroke.
