1020 short
TJ in FW
07-05-2007 20:06:42
Just picked up a JD 1020 gas that runs great but the battery runs down if left hooked up overnight. Any ideas where to start looking for the short?
Gerald J.
07-06-2007 20:58:21
 Re: 1020 short in reply to TJ in FW, 07-05-2007 20:06:42
Its not a short. If it was a short, it would be draing so much current it would be burning the insulation off the wires and maybe burning the wirs in two.
Since its negative ground for the alternator the suggestion to disconnect the positive battery terminal is unhealthy. It works just the same for leakage detection to unhook the negative (grounded) battery terminal and there is far less chance of shorting the battery with the wrench. Anything metal you hit with the wrench on the positive post is a short and that can cause the wrench to get hot very fast and the sparks can ignite the fumes the heavy battery load produces and the battery can explode in your face. When wrenching on the grounded terminal only dropping the wrench against the positive post can do that. Once the negative post is disconnected then unhooking the positive post is safe other than dropping the wrench across both battery posts.
Still you will have to do the circuit separation to find the leakage culprit.
If the tractor was original it would have been possitive ground with a generator and a very likely suspect would have been the cutout section of the voltage regulator which you could check easily by removing the generator belt. If the generator wants to turn, that regulator section is your problem. No test equipment needed.
A small 12 volt lamp is a safer indication of leakage than a test meter in case you turn on the lights or add a short while probing. The light will just go to full brilliance while the test meter may let out all its smoke and stop working for you.
Gerald J.
720 in pa
07-07-2007 05:10:23
 Re: 1020 short in reply to Gerald J., 07-06-2007 20:58:21
maybe i should have told him to disconnect the neg.terminal on battery,although im not familiar enough with this specific tractor to know if its positive ground or negative ground.also,i think anyone wrenching on machinery should already know that the terminal on battery thats not connected to the frame will be the "hot"terminal.
and yes,depending what kind of test meter you have,it will blow the fuse if you try to start tractor or turn on lights with test meter in place.i have been using this method ever since i am a mechanic,and it has yet to fail me.
machinery-man
07-06-2007 07:11:01
I found the diodes bad in my alternator...there is a kit but it has to be soldered in....I just purchased a new alternator and solved the problem...I don"t ever jump start tractor, but rather use a heavy duty charger if batteries are low..
720 in pa
07-06-2007 03:07:26
often times its the alternator or regulator.remove positive battery cable and put ammeter in between battery and cable,or if you dont have ammeter,lightly touch positive cable end against positive post on battery.if it is drawing,it should spark ever so slightly.
then remove main wire from alternator and repeat touching cable to battery.if it doesnt spark you know the alternator is the problem.
if this doesnt change anything,try removing varios different wires one at a time to see where your problem lies.good luck
Roy in georgia
07-06-2007 03:29:31
 Re: 1020 short in reply to 720 in pa, 07-06-2007 03:07:26
I was going to suggest the regulator or alt. but 720 has a test method that is simple but effective.I knew this but didn't think of it thanks for the reminder course 720 ha.ha.
