Can someone explain 3 postition pto on 3020?
Chris Comer
07-05-2007 16:25:04
My owners manual for 3020 shows ON ,Neutral and Brake position. It states that the pto should be in neutral when not using pto. My pto lever only acted like it had two positions. On and off or brake position. My pto is broke now but when I get it fixed, I want ot make sure its working properly and I want to know how to operate it properly. If anyone has one that works right can you explain it to me. I dont think mine has worked right sence I bought the tractor.
K.B.-826
07-05-2007 18:03:56
 Re: Can someone explain 3 postition pto on 3020? in reply to Chris Comer, 07-05-2007 16:25:04
The main reason they have the brake is for emergecy stops of large PTO driven implements. You need to pull the lever back towards you from the neutral position to engage the brake. Spring pressure should push it back to neutral when you let go. Avoid using the brake as much as possible, especially with implements that have a lot of momentum. They're not easy to replace, especially if it's a powershift tractor.
Mike M
07-05-2007 17:35:44
I think it varies by years. I have an early 4020 with the large lever on the RH side and it has on,neutral,brake. There is a spring loaded detent up under the dash that may need freed up so you can get that neutral spot. If you have this style pull off the access panel in front of you as you sit in the seat and you should see it. Others (I thinki side console models) have a small lever up on the LH side of the dash and they work differently.
ET
07-06-2007 05:08:05
 Re: Can someone explain 3 postition pto on 3020? in reply to Mike M, 07-05-2007 17:35:44
It's not uncomon to find that the cam under the dash that the detent rids on has a grove worn in it so you can barely feel the neutral detent. It may need to be repaced or built up.
Chris Comer
07-05-2007 18:55:52
Thanks for the info. Now I get it!
