Need a little advice on a JD 1010 RU
Fireman
07-05-2007 10:17:57
I just aquired a 1963 JD 1010 RU. The tractor is in excellent shape in apperance but has been sitting in a barn for about 10 years (not used at all) I am going to go get it this weekend and have been told by the owner that a battery and fresh fuel should get it going since it ran when put in the barn. Now I know that I need to change all the fluids, belts, hoses, etc when I get it home but I do want to get it running so I can load it on the trailer with ease. Anyone have any suggestions/pointers of what to do to get it running with little problems like for example should I spray some WD40 or oil in the head or do anything else before I try to turn it over? All help is appreciated, Thanks Sean
fireman
07-07-2007 14:31:59
 Re: Need a little advice on a JD 1010 RU in reply to Fireman, 07-05-2007 10:17:57
Well I went to go tinker with it today. Most importantly it runs! But the float seat is sticking so it is not getting fuel as it should, I first got it running with a little starting fluid but am only getting enough fuel to keep it running for a minute or so. No smoke and the engine sounds real good. It only has 2100 hours on it so I thought that was good. I know it needs a new belt, and I think it needs a throttle and choke cable. Hydralics work only thing I haven"t tried is to put it in gear. Once I clean out the barn I will try that.
Loren NC
07-09-2007 04:53:47
 Fuel problem in reply to fireman, 07-07-2007 14:31:59
Had the same problem keeping mine running when I first got it. Try this solution. Where the fuel line connects to the carb there is an internal fitting. Pull that out and you will find a microscreen. In my case it was COMPLETELY plugged with what looked like fuzz of some sort. Cleaned it all out and the tractor ran great.
Vermont John
07-06-2007 15:28:35
I just bought a 1010RU. 1963. It starts and runs. However, the owner says the plugs foul every few days. When I ran it, it does not smoke. I expected to see serious blow-by. Everything seems to work. It has a Freeman loader on it that seems to work.
I am getting it to my place in a couple of weeks. Any advice you guys would care to share would sure be appreciated.
Fireman - I would love to see how things work out with your RU.
Osage
07-05-2007 15:55:08
Fireman:
When you get her home, there will probably be a thousand things that you'll want to do. For what its worth I think I've done at least half of them to my little 1965 1010RU.
Aside from the all things that will make it run good, if its the "on-top-of-the-tranny" shifter model I'd suggest replacing the rubber boot on the shifter handle, otherwise any water can run straight down in.
Needless to say I like mine a lot, keep in touch with your progress.
Osage
Fireman
07-06-2007 06:33:45
 Re: Need a little advice on a JD 1010 RU in reply to Osage, 07-05-2007 15:55:08
another question, this is the first run in I have had with one of these tractors and I am noticing that all the pictures I see on the internet show a sea shell type rear fender and the one I have is a much larger fender (actually my wife said her Grandfather use to sit her on it when they planted tobacco. Is this common? Also I have been around JD tractors my whole life but didn't really get into all the technical stuff on them so one thing that pops in mind is what is this 2 speed pto that I am reading about 540/1000 I think. Can someone explain this to me? I know that a live pto continues to work when you push the clutch in and I am pretty sure this has it. The one thing I hadn't looked at yet was if it had power steering.
Thanks
Loren NC
07-06-2007 09:52:28
 PTO on a 1010 in reply to Fireman, 07-06-2007 06:33:45
If you look at the back of your tractor you will see two places to install the PTO shaft. Nearly everything I know of runs off of 500 rpm so there is little need to switch the shaft back and forth. By the way, most of the ones I have seen leak fluid around the PTO shafts. It is a simple task to replace the seals and you can buy them almost anywhere. Take an old one with you and let them match it.
There is a long lever on the left side of the tractor in front of the clutch pedal. That is your live PTO clutch lever. Yes, it will keep running when the foot pedal clutch is depressed.
msb
07-05-2007 14:38:10
Better take along a new set of points and condenser, a feeler gauge, screwdriver and a set of ignition wrenches. Points are probably oxidized and will not conduct current.You may get it to fire by scraping the points with a sharp knife.
machinery-man
07-05-2007 11:50:35
If the current owner has another tractor, I'd insert a good battery, new fuel and get him to pull me a few laps and loosen it up then pull start...you could get your oil pressure up this way till you gave the ignition some fire....might save a log of problems...you could even pull the plugs till you wanted to fire it up...
