44JD A timing question
phillip W.
07-05-2007 05:59:20
I am putting my A back together and and puzzled on the timing marks. If I line the crank and cam marks up, the cam to gov marks are not even close to lining up. I looked on a spare cam gear I have and looking at the marks on it I do not see how it could possibly line up. What am I missing?
P Browning
07-05-2007 07:20:44
 Re: 44JD A timing question in reply to phillip W., 07-05-2007 05:59:20
The two marks to establish timing between crankshaft and cam are on the INSIDE of the cam gear. They must align!
As for the governor gear marking and corresponding cam gear marking, you will find these on the OUTSIDE of the cam gear.
The sequence of basic engine timing is sooooo ooooo simple. (1) Ensure cam & crank gear marks align, (2) Ensure you have the flywheel keyed to the crankshaft, (3) When installing the governor, ensure the magneto drive flange slots are horizontal with the flywheel LH IMPULSE mark at 3:00 o'clock (The no. 1 piston is at TDC), and (4) Have magneto at "no. 1 just fired" to mate up with the horizontal magneto drive flange slots -- engine still at TDC all the while!!! You then trim out the magneto -- and if you need detailed instructions for that -- post back.
NOTE: If you have doubts about the relationship between camshaft and crankshaft, there is a simple test you perform to check that. THE FLYWHEEL MUST BE CORRECTLY POSITIONED ON THE CRANKSHAFT FOR THIS TEST TO WORK! (1) Ensure the no. 1 exhaust valve is set to spec (.020 for JD-A), (2) Slowly rotate the flywheel in the "run" direction until the tappet gap for No. 1 exhaust decreases to zero (just about to start opening the no. 1 exhaust valve) & STOP! Check the location of the LH EXHAUST marker on the flywheel. It should be not more than ONE INCH from 3:00 o'clock. This is the valve timing test -- see para 60 in your I&T (JD-4) Shop Service Manual. (PatB)
John T
07-05-2007 06:41:46
Phillip, Ifffff f the flywwheel is on the correct crank spline, as far as the crank to cam timing is concerned, when the Flywheels Left Hand Exhaust timing mark is at the 3 o clock position lined up with that flat mark on the tractors side IF THE CAM N CRANK TIMING IS CORRECT the left cylinders exhaust valve should just be beggining to break open.
Then once you have the crank timed to the cam, the governor to cam can be timed just like Mike told ya..... Again if the flywheels on the correct crank spline and the cam n crank are in time, when the Flywheels left hand Impulse timing mark is at 3 o clock the governor gears open female drive slot (where mag mates) ought to be in the flat horizontal fore n aft location he mentioned.
I bet if you run these checks then some of those "timing marks" may become more apparent n correct. If not (far as I know, which aint worth much really lol) what I posted above still has to be true n take precedence in case swapping cranks or cams isnt yieldng the correct apparent timing marks.
Mike, think we have this correctly covered??? its NOT tricity so I certainly defer to you more mechanical gents.
John T
Mike M
07-05-2007 06:19:30
Are you looking at the right marks ?
The crank to cam gear marks are the ones on the insides and the gov. to cam marks are on the outsides. I don't think they will all be aligned at the same time either as you have to turn the engine some. The main concern is the crank to cam. The gov. really doesn't matter as long as when the engine is at TDC on #1 LH cyl. that the impulse coupling drive slot is Horzontal - -.
