Jonathan: The basic kit you generally receive is a needle valve and seat, some gaskets, and a maybe new throttle shaft. Like the guys have suggested, you'll likely need to go in further to solve your idle problem. One thing about probing in a carburetor with those drill bits...I suggest that unless you really know where you are going you try some soft wire first. It can't hurt, it might move the rusty slug, and if it doesn't, you can use the drill bits, in your finger tips first. Had a fella a while back go at it with a fast drill and it went right through the carburetor port wall. You're going to need to remove ALL of the brass plugs to gain access to all of the ports. Two are inside the bowl area. Those plugs were placed there as plugs after the body was drilled and machined. I would suggest that you pull the central nozzle as well as there is a good chance that there is dirt and debris trapped in there if you have slugs plugging the ports. If you don't, another might be near ready to break loose right after you re-install it. Check your shaft bushings, too. Air getting in around the throttle shaft can cause idle problems, though probably not as severe as you describe. Roberts can supply the brass plugs, too. A fresh carburetor looks really nice when it's dressed out with new outer hardware, and the next time they'll be easier to remove. Frank Frank
