4020 weep holes again Hypothetical scenario :]
Nylon
07-04-2007 16:34:02
Are the weep holes connected via a channel in the block? Or does one weep hole service one cylinder? I pressure washed the tractor again..I got the leak stopped (I think) out of the valve cover. Which was running down (pretty heavy) behind the starter. As I pressure washed the area around the forward weep holes, I was seeing the weep hole halos (3" diameter circles around the holes very slightly discolored but visible)were hydrophobic. Meaning water somewhat beaded off that area....so wondering if somehow valve cover oil leaking INTO the 2 weep holes below it on the block behind the starter could have been warm exhaust gassing out the other weep holes an oil film and creating said halo. Yes, no maybe or looney as a fruitcake / carrot jello?
msb
07-04-2007 19:06:08
 Re: 4020 weep holes again Hypothetical scenario :] in reply to Nylon, 07-04-2007 16:34:02
One weep hole for each cylinder and they are in no way connected. Just watch it for a while to see if the water stops coming out of the weep hole. Chances are you have blown some water in the hole with the power washer.I have seen it before or if you are really brave, you could taste a very,VERY small amont to see if it is sweet like permanent antifreeze tastes, but I would take a wait and see approach.
Nylon
07-04-2007 22:16:07
 Re: 4020 weep holes again Hypothetical scenario :] in reply to msb, 07-04-2007 19:06:08
Well worth a question anyway. There is no actual watery discharge. Just a discolored halo around the weep holes. Nothing to taste...just that the halo surrounding the hole was more like oil than anti freeze. Antifreeze dissolves readily in water...the halos have more of an oily trait...like trying to paint latex over 100% silicone caulk. The halo is not wet or even damp...just visible.
dds-inc
07-04-2007 17:55:20
Well...
you wish.
Sorry.
buickanddeere
07-04-2007 17:45:10
Weep hole water = new sleeves & seals. No ifs ands or buts.
