B JD HYDRAULIC PUMP INTERNAL SEAL/S
ZANE
07-04-2007 14:41:35
This is a 1937 modle B JD on iron. I have taken my pump apart to try and figure out why when oil is put in the lift it soon ends up in the differentail section and the lift is dry. I am sure it is leaking from the pump and not the lift cylinder. I have already carefully inspected the piston and cylinder and it is not leaking and it will leak out even with the lift idle.
What do I need to do to fix it?????
Thanks, Zane
Kristopher Rohde
07-06-2007 11:53:30
 Re: B JD HYDRAULIC PUMP INTERNAL SEAL/S in reply to ZANE, 07-04-2007 14:41:35
Can anyone tell where the internal hydraulic pump is located on a European 1040 John Deere
Green Relics
07-05-2007 12:18:23
I concur with dds-inc, There are two, I call them Quad rings on the main shaft that need to be replaced. Just hope your shaft and housing is not too scored up. That could wipe out any new seals.
dds-inc
07-04-2007 16:28:07
there are two seals on the pto shaft on the transmission side of the unit. replace the seals. Get a service manual too.
