420W Touch-O-Matic Seals
Andrew M
07-04-2007 13:53:34
I need some help on the quantity of seals for the crossover valves located behind the selector lever . The parts manual shows two washers and a seal. When I disassembled the valves I found only one metal washer and one seal. I guess its possible that one of the seals has disintegrated. Any one familiar with replacing the seals in the selector valves?
Andrew
420 430
07-06-2007 20:12:47
 Re: 420W Touch-O-Matic Seals in reply to Andrew M, 07-04-2007 13:53:34
The part # should be m3150t they are little cork seals. they sub it 40 model parts book M1116T should be the same I just got some from deere the other day good luck
Dave H
07-04-2007 20:26:40
Andrew
I went thru that but it has been a couple of years. As I recall, the seals as listed are not available, but replacements are. It sounds like to me you have a sub there for the stuff listed in the parts book.
Maybe someone with more courrent memeory will chime in.
A trip to the stealer or the web site might shed some light.
