3010 rear pto
Bruce Giese
07-04-2007 12:19:05
kind of a stupid question do I need to split the tractor to remove the rear pto housing, I need to fix the upper drawbar positioning holes and replace the gasket I think I already know the answer just want to confirm it thanks
msb
07-04-2007 19:11:17
 Re: 3010 rear pto in reply to Bruce Giese, 07-04-2007 12:19:05
If you are talking about what I think you are then that is a part of the transmission/differential case. The PTO plate will come off without splitting the tractor.
Bruce Giese
07-04-2007 19:27:34
 Re: 3010 rear pto in reply to msb, 07-04-2007 19:11:17
Msb
this is the housing that is also the upper drawbar support and what the lower drawbar support bolts to along with the 3 point swayblocks, I have it unbolted and the rear seal plate out but cannot pull the housing off due to a washer that will not come thru the housing, if this link works it should be the diagram that I"m dealing with and part 22 is what I need to get off and part 17 is what is stopping me from getting the housing off. thanks
Link
