Front tire tube replacement on JD 60 row crop
mgw
07-04-2007 10:33:33
Happy 4th of July,
I have a JD 60 row crop. The front tires are firestone 6-ply with an inner tube.
The stem on the tube has a hole in it. I filled the tube and duct taped it to keep air in the tube.
Do I need special tools to replace the tube? I read other posts and know how to jack up the front. I just want to make sure that when I take the tire off I can complete the job.
P Browning
07-05-2007 04:30:04
 Re: Front tire tube replacement on JD 60 row crop in reply to mgw, 07-04-2007 10:33:33
Go to WalMart, Home Depot, or Lowes and buy some Slim -- pump it into the front tire then drive it some -- You may need two cans -- may seal up on its own! (PatB)
P Browning
07-05-2007 04:31:41
 Re: Front tire tube replacement on JD 60 row crop in reply to P Browning, 07-05-2007 04:30:04
I meant to say Tire Slime! Look for it where they sell the lawn mowers and tires for lawn maowers. (PatB)
johns48jdb
07-05-2007 04:04:53
just because air is coming out around the valve stem doesn't mean that the stem is bad. any type of hole in the tube would cause air to come out around the valve stem. if this is a using tractor that you mow or bush hog with you may have picked up a thorn. they are hard to find in a tire. one cure for a tractor that is used alot where there is thorns and you keep getting flats is to take an old inner tube and cut it half into all the way around. you'll have a donut left. put the outside of the old tube in first then then new/repaired tube. thorns that come through will usually be broken off by the fricition between the two tubes and not make it into the inside inner tube.
dds-inc
07-04-2007 16:26:24
Don't know what you mean by dacking, but if your tractor doesn't have a rollomatic, then you can run one tire up a 2x6 and take the rim off the hub. If you do have a rollomatic, then you'll have to run one tire up a ramp
you have to have two tire irons and dish soap to get one side of the bead off the rim. Then you put the other tube in.
Or you can just take the whole thing to a tire shop if you think you're inexperienced.
mgw
07-05-2007 04:45:53
 Re: Front tire tube replacement on JD 60 row crop in reply to dds-inc, 07-04-2007 16:26:24
Thanks for the replies,
I am almost certain the stem has the hole. The stem is old and rough. I think I caused the hole when I filled it with air last time. I pushed to hard on the stem and when I bent the stem I heard the air leak. If I angle the stem just right the leak will stop.
When the air started leaking I did put some fix-a-flat in the tube. After that I duct taped the stem into the position I needed to prevent air loss. I then brush hogged about 3 acres and the tire is still full after 4 days. I haven"t had the guts to remove the duct tape yet.
I have a roll-o-matic and use the tractor for brush-hog work, plowing, raking, and moving round bales on a 30 acre horse farm. My front field is weeds so I may have picked up a thorn.
Are you saying that if I take the wheel and tire to Discount or Belle Tire they will have the tube to replace what I have? I will probably try to do it myself but if I can take it to one of those shops at least I can use them as a last resort.
MGW
