329 vs 404 diesel in 4020
Nylon
07-04-2007 10:16:08
Ok ..nuther dumb question. While looking for parts here on yt website, I found bearing sets for 329 diesels and 404 diesels. I had always assumed I had a 404 but now I am wondering what it is. I know the addage about assume. How do I tell which one I have in my tractor. It is a 68 with synchro. The # stamped in the side is:23e202141 Other side of block has part # R408807 and a 43 also cast on it.
Were 329s sprinkled through the 4020 line? My I&T has no information or anything refering to a 329. In fact the I&T says diesel is a 405 and the gas is a 341. The owners manual says it is a 404 as well. I am pretty sure I have 404 but this made me wonder. Thanks again for info.
buickanddeere
07-04-2007 17:48:28
 Re: 329 vs 404 diesel in 4020 in reply to Nylon, 07-04-2007 10:16:08
The only way a 329 or 414 snuck in there is if somebody parted a 2510,2520 or 4030 and transplanted more than just the Dubuque style engine.
Nylon
07-04-2007 22:23:19
 Re: 329 vs 404 diesel in 4020 in reply to buickanddeere, 07-04-2007 17:48:28
It may just be listed in an un intuitive fashion.
Main Bearing Set - Available in STD, .010, .020, .030 For 2840, 3120, 3130, 3530, 4020, 4030, 4400, 4420, 4425 with 329 Diesel Engine. Specify size in Comments box when ordering. (Part No: R-RE27352S6) $102.50
----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- Main Bearing Set - Available in STD, .010, .020, .030 For 4000, 4010, 4020, 4040, 4230 with 404 Diesel Engine (To EngS#214999) with Block #R40930& (From Eng S#215000) All. Specify size in Comments box when ordering. (Part No: R-AR74814S6)
95EB
07-05-2007 07:08:21
 Re: 329 vs 404 diesel in 4020 in reply to Nylon, 07-04-2007 22:23:19
You are absolutely out of your mind to be ordering parts from this site, as it's obvious that they don't have a clue! For your own sake, find a JD dealer!! What you posted is total misinformation. Again, 4020 tractors were NOT built with 329 engines!!
Gerald J.
07-05-2007 00:48:21
Probably after you place the order, they call and ask which engine. The part numbers given don't come close to any part numbers in my 1968 4020 parts book and it shows different parts for gas and diesel and for each of several block casting numbers and for different clearances. Looking at a Cee Tee catalog from several years back its noticeable that rod bearings fit more engines both gas and diesel than mains. And then there's the thrust bearings too. My parts book probably shows the part number for one bearing, while a 3020 takes 3 mains, or 5 mains and a 4020 takes 5 mains or 7 mains depending on whether its gas or diesel. Take a look at Shoup to see what they show, then go to NAPA and see what they show. But don't buy bearing until you've inspected, gauged, and maybe ground the crank. Then let the machine shop that ground it provide bearings to fit.
As for weeps, the later 4020 didn't have weep holes. I think there's a service bulletin suggesting they could be plugged and there would be fewer customer complaints and no more engine damage. If it isn't running out antifreeze, it might be just a tiny seep from sleeve flex due to the bang of diesel combustion. Might be good to have an anticavitation additive in the coolant to slow the perforation of the sleeves.
And then at this age, O rings could be dry and hard too. If you want it perfect forever you simply have to remove every possible part and replace all that could wear, or you could run it a few thousand hours to see if anything changes in oil consumption, fuel consumption, or weep rate and fix it when any of those go out of tolerance.
Gerald J.
Nylon
07-04-2007 16:19:43
Good info guys thx. It must be that the 329 uses the same bearings as a 404. In certain serial. If you do a search for 4020 in the model # box at the top of page on yt, it will list the parts available from yt. If you look at bearings, it groups several models together. I had a fellow take a look at my weep holes the other day and he was saying something about 329 also. So when I saw that in the bearings section I was wondering if a 4020 ever came with a 329 in it. But those bearings are sold as fitting a group of tractors.
I was investigating the kind of money it was going to take to freshen things up in the 4020. If my o rings at the bottom of the liners need replace that means that everything is coming apart anyway. If there is 30% or even more life left in the parts then I may as well replace. I really like to have everything on hand before doing a project. The only way to do this one yhough is to pull it apart and read stampings and measure.
95EB
07-04-2007 18:27:04
 Re: 329 vs 404 diesel in 4020 in reply to Nylon, 07-04-2007 16:19:43
If I were you, I wouldn't take any of the parts information on this website as the absolute gospel. 329's and 404's aren't even distantly related, other than both were built by Deere.
Silver Pig
07-04-2007 20:24:41
 Re: 329 vs 404 diesel in 4020 in reply to 95EB, 07-04-2007 18:27:04
I wouldn't take ANYTHING posted on this website as gospel.
wolfman
07-04-2007 18:48:06
I'm not totally sure the 329 is Deere. It in a 6 cyl and the 219 in a 4 happen to have the exact bore & stroke of the 329 in the 1690 etc Case and the 219 in Longs, Zetors and others. The 2440 & other Deeres had that 219 and I think somewhere on manifold or block you can read Romania or ??? .
jdemaris
07-04-2007 18:55:37
 Re: 329 vs 404 diesel in 4020 in reply to wolfman, 07-04-2007 18:48:06
I don't know where you get the Romania idea from - but I can tell you this much. I was a Deere mechanic from the mid 1960s on to 1990 and worked on many 152/164 three-cylinders, 202/219 four-cylinders, and the 329 sixes as used in the 540 skidders and the 4030 ag. tractors. They were all basically the same engines - just with different numbers of cylinders - same basic block designs, same basic rods and pistons, same valve and cylinder head designs, same cooling system designs, etc. Only sort-of oddball in the bunch was the four cylinders since they had a balance problem and required twin balancing shafts. Just about all U.S. made - not counting a few Manheim/German engines like used in the 830s, or a few Saran/France engines used in the later 350 crawlers.
J Schwiebert
07-04-2007 15:02:16
Oh Boy. I have not done this for a few years, but there are also differences in the thrust bearings in the early and late on 404 engine. Me I am like Jerald, did that work in a formr life time, not now. Anyhow I am always at these people that want to order bearings before measuring the crank. How do you know the crank will take standard size bearings?
jdemaris
07-04-2007 12:46:48
The 329 was an engine built on the same format as those used in 350/450 crawlers, 440/540 skidders, 830,1020,2020 tractors, etc. 3 cylinder diesel versions were 152/164 cubic inches, fours were 202s/219s, sixes were 329s, etc. Most of these engines shared bearings, pistons, sleeves, etc.
The heavier built 404 used in the 4020 was also used in a four cylinder version in the 3020s.
Bob
07-04-2007 11:39:09
The Dubuque-built 329 has a totally different bellhousing pattern, and is no where NEAR close to fitting in a 4020.
Later models that used the 329 have a different clutch housing.
Gerald J.
07-04-2007 10:42:40
329 were never a 4010/4020 option. Early diesels had a 4-1/8" bore instead of the later 4-1/4" bore, 380.5 cubic inches. Later sleeves fit the early blocks, but rods and pistons from the newest 4020 will give low compression in the early blocks because the later blocks are not quite as tall as the early blocks.
There are 404 and 6404 with the same displacement, but not too much else in common. Only the 380 and 404 were in the 4010 and 4020. Gas were 302, 341, and 360 depending on which version.
Remember there were essentially three vintages of 4020 with breaks at 91,000 and 201,000. The late 4020 have so little in common with the earlier 4020 that they have separate parts books and shop manuals. The late 4020 engine has no crankcase ventilation pump while the hydraulics are totally different.
There were also incrimental changes in the engines during a vintage run that are detailed in Deere Service Bulletins.
Gerald J.
Nylon
07-04-2007 11:39:45
 Re: 329 vs 404 diesel in 4020 in reply to Gerald J., 07-04-2007 10:42:40
Thx Gerald,
I have that notion of 3 general serial ranges in my mind. Although my I&T simply breaks the book by the major serial break. I have a 68 which makes it a middle serial range. Any way to tell from block serial #? This could have had an engine swap at some point in its life too.
Gerald J.
07-04-2007 13:52:49
 Re: 329 vs 404 diesel in 4020 in reply to Nylon, 07-04-2007 11:39:45
third party image
Actually '68 was the last year of the middle range, like my gasser.
I don't have any information on block serial numbers. My parts book just says there were several different casting numbers and gives different part numbers for them assembled with some bearings. I don't think the shop manual has any more details, but I hope to never see the inside of my engine, so I've not studied that part of the manual closely. I've done enough engines to know how and its not work I like to do. It did all the work I wanted it to do last week running probably 10 or 12 hours doing side dressing and spraying.
It certainly is possible there was a block or engine swap in the past 39 years but its also more possible that you have original parts. Many a 4020 has rolled the hour meter over more than once. I believe mine is one of those. The groove on the generator pulley was worn parallel, the groove on the water pump pulley was worn but not as much (larger diameter). Its been painted at least once (the PTO covers won't go on their storage spots because the paint is too thick) and the engine has been apart since it was last painted judging by the 12 point wrench marks on the head and bell housing bolts. With the proven propensity of failure of tachometer and tachometer cable, hour meter readings are rarely exagurated.
At one time, I'm sure the factory had a record of what engine SN was installed in each tractor SN and maybe they still do. I think a two cylinder club has some of those details and will search them out for a fee. Since I've been adjusting the attitudes of my 4020 to do the work I want it to do (MF loader, tall narrow tires, fewer shrouds, convntional battery, easy to climb step, ammeter, alternator...) I'm not worrying about whether the engine is the original, only that it runs every time I want it to run and isn't running out of oil or fuel. And those it is doing well.
It can be important when looking for parts to be sure to include at least the casting number from the block as well as the tractor SN and the engine SN.
Gerald J.
cannonball
07-04-2007 10:36:24
A 329 was used in a 4030... also used in some combines and a 2840
MAY GOD BLESS THE USA
