2640 Front end alignment
Blacktree
07-03-2007 14:35:09
I am operating a 2640 that has a lot of play. The shaft thru the box was loose. We tightened it and helped a lot. The front tires are badly worn on the left side. Does any one know how to obtain proper alignment? Any help is greatly appreciated.
flying belgian
07-04-2007 08:21:30
 Re: 2640 Front end alignment in reply to Blacktree, 07-03-2007 14:35:09
pound a nail through a board and jack front wheel up. hold nail against middle of tire and spin wheel which scribes a mark around dia. of tire. Do this on both tires. then let it back down and measure between scribe mark front and back of tire. give it just slight toe in. This is more acurate then measuring between sidewalls as they can bulge a little here and there around tire.
Tx Jim
07-04-2007 04:27:55
 Re: 2640 Front end alignment in reply to 1 Dollar, 07-03-2007 14:35:09
Measure center to center of tires, front and rear. Rear measurement should be 1/8 inch more than front. Check bellcrank in center of frt axle as it's probably loose. Tx Jim
Blacktree
07-04-2007 08:41:33
 Re: 2640 Front end alignment in reply to Tx Jim, 07-04-2007 04:27:55
Thanks but what I'm refering to is alignment not "toe in". The tractor pulls to the left real bad. All linkage seems to be fine just out of alignment.
