JD 1120 TRANSMISSION WITH HI/LO UNIT
ERICSTP
07-03-2007 07:19:05
MY TRACTOR IS MAKING A VERY HIGH WHINNING NOISE IN THE LOW RANGE GEARS AND WHEN SWITCHED TO THE LOW RANGE OF THE HI/LO UNIT. AS YOU MOVE UP TO THE HIGHER GEARS THE NOISE SEEMS TO GO AWAY BUT WHEN IN THE HI RANGE OF THE HI/LO UNIT I CAN HEAR SOME CLUNKING AND RATTLING IN THE TRANNY WHEN SITTING IN NEUTRAL. THE HIGHEST AMOUNT OF WHINNING IS IN THE LOWEST GEARS. COULD THIS BE A BAD INPUT SHAFT BEARING, OR A BAD COUNTER SHAFT BEARING? I DO HAVE THE TRACTOR SPLIT APART AND I AM HAVING A VERY HARD TIME FINDING THE PROBLEM, EVERYTHING SEEMS TO BE IN GOOD SHAPE EXCEPT FOR THE SHAFT THAT RUNS THROUGH THE TRANNY PUMP, THIS SHAFT SHOWS SOME WEAR AROUND THE AREA THAT THE BEARINGS RUN. PLEASE HELP, THESE PARTS ARE VERY EXPENSIVE. THANK YOU.
buickanddeere
07-05-2007 21:27:28
 Re: JD 1120 TRANSMISSION WITH HI/LO UNIT in reply to ERICSTP, 07-03-2007 07:19:05
Did you check the oil pressure and run an oil analyis before tearing the tractor apart? Did these noises change when under heavy load, coasting or while holding back while decending hills? Were the noises the same when running with the rear wheels blocked up off the floor? Are you eyeballing the parts or measuring with internal & external micrometers? Have you measured play with a dial micrometer? How many hours and what kind of use has this tractor seen? Sometimes with tractors of this age its cheaper to either just "drive her till she drops" or trade it in. P.S. Typing in capitals is considered yelling and is frowned upon.
ERICSTP
07-06-2007 04:49:39
 Re: JD 1120 TRANSMISSION WITH HI/LO UNIT in reply to buickanddeere, 07-05-2007 21:27:28
Thank you for the reply
I did not check the oil pressure, i assumed because the hi/lo unit was working that the oil pressure from the tranny pump was ok. Now that i have done more research on these tractors i now know that the pump can be fine but there can still be an internal oil leak. The tractor makes the whining noise in low range with no heavy load. This noise will intensify when i hook a baler to tractor and run the pto. Tractor has approx 4000 hrs, was used for spraying, ran the roads alot. Have not measured end play yet. Did not check for tranny noise while tractor was block up off floor. The tractor was making enough noise that i thought for sure a bearing would be gone.
