4400 D that will only run at full throttle
mark painter
07-03-2007 07:03:47
I was using the tractor last night cut it off got up this morning to go back to work tractor wouldn't start when it did start it will only run at full throttle and when you put any load on it it slowly drops rpm's until it cuts off.
machinery-man
07-03-2007 19:07:34
 Re: 4400 D that will only run at full throttle in reply to mark painter, 07-03-2007 07:03:47
that's a strange one...will try to remember that in case I run into the problem....
F-I-T
07-03-2007 09:25:37
Does it have a fuel shut off cable ? Perhaps it did not return to the correct running position? I'd check to make sure the shut off lever on the pump is in the full "On" position.
F-I-T
07-03-2007 09:25:31
machinery-man
07-03-2007 07:35:48
Obviously your governor is not working and I would suspect electrical malfunction, wiring connections, check at the main harness. There are various relays. Personally I would recommend a deere technician on this one. It may be something simple but tracing it down is tough. Your post did not explain exactly what you were doing. I had problem with my 4400 not starting and it was the main wiring harness connections. These tractors don"t have computers but they have relays and enough electrical to drive you batty...also if you mess around and short some of them out you"ll find the need for a boat load of money as there is only one source. I have a technical manual but on problems it can be sketchy. May some one else can weigh in on post.
mark painter
07-03-2007 17:11:42
 Re: 4400 D that will only run at full throttle in reply to machinery-man, 07-03-2007 07:35:48
Thank you guys for your help it ended up being a bad fuel filter
