Clutch on 38 G
Gulfbird
07-02-2007 18:53:31
I have a 1938 G, SN# 4435 that is leaking oil into the clutch. My IT manual shows two types of clutch assemblies and I"m not sure which assembly is correct for my tractor. The manual shows one assembly with two clutch discs and no oil seal behind them. It shows another assembly with three discs and an oil seal behind it. My tractor has three clutch discs and no oil seal behind it. Did JD make a change that my manual doesnt show or what? Help!
F-I-T
07-02-2007 21:00:54
 Re: Clutch on 38 G in reply to Gulfbird, 07-02-2007 18:53:31
Your "G" is a pretty early one, and when I look at the early, middle, and late parts books, I don't see an oil seal in any of the pulley configurations. Those pulleys have a bushing in towards the rear, so that a nice slip fit with an unworn bushing, on an unworn crankshaft journal, and a nice clean drain back hole in the first reduction gear cover pretty much keeps the oil to a minimum. The operating sleeve has grooves in it so that when it is spinning, the oil is slung outward away from the crankshaft so that promotes drain back as well. So, install a fresh bushing, clean and repack the idler bearing, and make sure that when you park it running, the transmission is in neutral and the clutch is engaged so that the pulley is spinning, which will allow the oil to be slung away from the rear of the pulley. No oil seal in there unless someone customized it.
Frank
