1020 carburator load jet. MSB
lekander883
07-02-2007 17:24:23
ON THE BOTTOM OF MY CARB. I HAVE THREE SCREWS. FRONT TO REAR I HAVE A THREADED BOLT, THAN A BOLT WITH A HEAD ON IT, AND THAN A SMALL CHROME CYLINDER WITH A TINY THREADED SCREW COMING OUT FROM IT AND A WIRE. I HAVENT TURNED ANYTHING YET. I WANTED TO GET IN TOUCH WITH YOUR THOUGHTS AS TO WHICH ONE TO TRY. ONE OTHER THOUGHT I HAD WAS THE FUEL FILTER, BUT IM NOT SURE WHERE IT IS? THANKS AGAIN, TROY ALL HELP APPRECIATED
Mike M
07-03-2007 04:31:12
 Re: 1020 carburator load jet. MSB in reply to lekander883, 07-02-2007 17:24:23
I think ? there is a strainer in the elbow/fitting at the carb. where the gas line hooks up.
msb
07-03-2007 07:01:10
 Re: 1020 carburator load jet. MSB in reply to Mike M, 07-03-2007 04:31:12
Good thinking, Mike. The problem could well be a partially plugged screen or line.
msb
07-02-2007 18:49:01
The small chrome cylinder has a thumb screw in the end of it. That is what you want to try adjusting. It has an electric solenoid valve in it that shuts the gas off when you turn the key off. It stops dieseling common to later gasoline engines.
