Fuel Shut-off drips - 48-A
Sam in MN.
07-02-2007 14:09:13
With the sediment bowl off and the valve turned off, there is a drip of gas every 2 to 3 seconds. Doesn't appear the crankcase is filling as the oil looks good and level right in there. Didn't help to tighten the side compression nut either.
Is this normal, or should I replace the crazy thing?
Thanks,
Sam
F-I-T
07-02-2007 21:14:48
 Re: Fuel Shut-off drips - 48-A in reply to Sam in MN., 07-02-2007 14:09:13
Here's what I would try.
Take the valve out and see if you can see a parting line on it. A lot of the newer stuff is zinc die cast and there can be a slight seam that you can sometimes lap out. Spin it in your drill if it will fit, and use a bit of 000 or 0000 Clover SC lapping compound or equivalvent. Use something very fine. If that does not do the trick, put a bit of compound on the male valve and try to lap the seat in the bowl base using the lapped valve. It has worked for me in the past.
Frank
johns48jdb
07-02-2007 19:03:30
i'm not clear about where your leak is. is it the sediment bowl or the 3 position shut off valve? just curious if you'll bought jd stuff or tsc stuff? if its the 3 position valve you might take it apart and with some steel wool clean it up a little bit and retry it. i had to tighten my nut up to where it was nearly impossible to operate the lever to turn it in any direction, but it did stop finally and hasn't given me any trouble for 7 or 8 years now.
Kent Petersen
07-02-2007 18:57:46
i got two new ones at JD dealer they are correct for 48 A about $35.00 complet assy this is fuel bowl it screws in to tank has screen, valve shut off, bail and glass bowl ect lo Kent
two cylinders saves gas
07-02-2007 15:16:24
I bought a brand new sediment filter , put it on and it leaks , uhh. I asked a few people they said that the seal inside there isnt of very good design, as i have had others leak too. I added a needle valve after, in the line to give me a good seal.
