1936 B starting problems
Jeff Oliver
07-01-2007 21:31:10
We have a 36 B that started really good when we got it. Could uually turn it over once and it would pull the flywheel out of your hand. Now you can turn and turn and nothing. Pull it about 3-5 ft and it fires right off and eems to run fine.
I'm going to pull the plugs and check them (more than likely replace them) and check to make sure when I turn it by hand i am getting a good spark. Do I need ot pull the carb also and clean it good or get it running and sun some sea foam through it? Want to get it back to starting like it did and start taking it to shows again.
Any other ideas or things to check?
Ralph Oliver
07-02-2007 22:18:04
 Re: 1936 B starting problems in reply to Jeff Oliver, 07-01-2007 21:31:10
Jeff, E-mail me please!
I have a 39 B, and a 41 B.
(South Dakota)
John T
07-02-2007 04:37:19
Jeff, When I hear a hand start mag equipped tractor starts n runs fine if pulled but is hard to hand crank, the FIRST thing that comes to mind is a weak impulse spring or an inoperative impulse assembly. Each 180 of crank/flywheel revolution the mag needs to make a loud sharp SNAP as compared to a weak faint clunk. I would pull the plugs for easy cranking and have the plug wires to within 1/4 inch from tractor steel and see if BOTH make a good visible blue spark as opposed to a faint thin wimpy yellow spark. It takes a good strong blue spark usually caused by a sharp loud mag SNAP for good hand starts. NOTE if she dont SNAP see if loosening the mags mount bolts makes her snap?? If so add an extra mag to governor gasket n see if that stops the binding.
Next thing I suspect is the points, try to non abrasively clean/buff/polish them and set the gap if they are good but gray oxide coated but replace them if badly burned or pitted or all carboned up.
ALSO try a fresh set of plugs as Plugs and Points are the prime causes of a weak mag spark. I agree with the previous post, I use the hotter deep reach side wire electrode plugs like Autolite 3077 in my older hand crank tractors that use the 7/8 plugs.
Where the start impulse timing set at ????? it needs to be right at dead TDC (left Hand Impulse flywheel timing mark at 3 o clock) or perhaps a degree or two before for agood hand stars but if it start timed too slow it can be harder to start.
There can also be carb issues which we can address if needed, but Id start with cleaning n gapping the points (or replace if needed) and fresh Autolite 3077 plugs n check the start impulse timing for TDC n see what happens.
John T
Jeff Oliver
07-02-2007 06:23:44
 Re: 1936 B starting problems in reply to John T, 07-02-2007 04:37:19
The mag snaps good I can hear it ok but am going ot check the spark also. I'll check the points as well and see what they look like and clean them is needed also.
Pappy
07-01-2007 22:07:08
Sounds like you might have a magneto problem. Do you hear the magneto snap whey you turn the flywheel? Check for spark when rotating the flywheel by hand. If no snap, check the impulse spring in the magento.
CalJim
07-01-2007 21:57:19
I just went through this on my 36 B. Started out with Champions(my first mistake). Tractor would start but took 8-12 pulls. Switched to Autolite 3077s, now starts on 3rd or 4th pull. CalJim
Gary from Muleshoe
07-02-2007 04:20:35
 Re: 1936 B starting problems in reply to CalJim, 07-01-2007 21:57:19
I agree with Jim, get rid of Champion plugs if that is what your running. I switched my 1940 B over to the same Autolites and now it will start in the 1st or 2nd pull. Also you might want to check you breather, it may not be getting enough air flow.
