1020 choke lever in our out?
lekander883
07-01-2007 19:55:09
1020 runs very well when choke is pulled out, and will sputter when pushed in. Just bought it so not sure if its choked when pushed in. Very clean tractor with nice loader and back blade $7350 how'd I do?
CharlieMc
07-02-2007 10:45:04
 Re: 1020 choke lever in our out? in reply to lekander883, 07-01-2007 19:55:09
On my JD1520 the choke is on when the knob is pulled out. The more it is pulled out the more it is choked. So it sounds like yours is operating normally.
You'll know more this winter when you need to choke the tractor to get it started.
Hope this helps.
Mike M
07-01-2007 20:09:10
It is possible someone hooked it up wrong ? I'd pull off the air cleaner hose at the carb. and look for sure. Knob pulled out choke should be shut. If it is correct and it will only run when choked then you need to open up the carb. adjustments and if that don't work the carb. is plugged up.
msb
07-02-2007 08:29:31
 Re: 1020 choke lever in our out? in reply to Mike M, 07-01-2007 20:09:10
Could also be the load speed jet is too tight. Its the one on the bottom of the carb. Close it and then open it about 1 1/2 turns.When you get it running with the choke all the way in, slowly close the load speed jet until it just begins to lose power,then open it up 3/4 of a turn. That should be real close to the optimimn adjustment.
Its also possibe the intake manifold gasket is leaking vacuum. Try tightening the mounting bolts a bit.
