J D 14T baler
Glen in Michiga
07-01-2007 18:10:12
I have a 14 T baler that works great but wont make a tight bale! I have the tensioners turned all the way down. Someone said something about replacing the boards? Thanks
msb
07-02-2007 08:17:52
 Re: J D 14T baler in reply to Glen in Michigan, 07-01-2007 18:10:12
Too small of a windrow will cause this too.Baler should make 11-13 strokes per bale. If your windrows are light, try slowing the PTO speed down and speed the ground speed up a gear.
lloyd b. east
07-01-2007 18:45:27
I have had a couple of 24t balers and they are similar to a 14t. I know they have a couple of plates on each side that stick out into the side of the hay and help keep it from going back toward the plunger. Also it should have dogs on the top and bottom that keep the hay in place once it has been plunged. Make sure the springs are good on them. Just my .02
Glen in Michigan
07-02-2007 12:06:38
 Re: J D 14T baler in reply to lloyd b. east, 07-01-2007 18:45:27
ok Thanks for the help. Glen
