How tight valve cover bolts?
Nylon
07-01-2007 15:30:42
Searching operators manual and I&T and cant find a torque value. Probably just not seeing it.
F-I-T
07-01-2007 18:55:36
 Re: How tight valve cover bolts? in reply to Nylon, 07-01-2007 15:30:42
Is this the 4020 you've been working on? If so those capscrews are only 1/4"-20, and my torque chart says 9 ft-lbs maximum. I wouldn't use anything larger than my 1/4" drive tools, a fresh gasket, and maybe a bit of Permatex. And, if it is the 4020, don't rely on two cylinder tricks to set those valves. Looser is certainly better than tighter, but since it's been a while since I set the valves on the 4440 and the 4020 projects I had, I won't guess, so use the book.
Best to post the model of the tractor for which you are asking questions. It's tought to keep up with the different threads. At least it is for me.
Frank
P Browning
07-01-2007 17:16:46
No need to keep looking! It isn't there. Some things you just have to have a feel for. All you want to do here is mount the cover and have no leaks. Clean & straight surfaces, a new gasket and perhaps some soft version gasket sealer works for me. I use Permatex no. 3 form-a-gasket on the gasket itself.
To avoid going back in later to check tappet settings at HOT, take the shortcut many JD service men used -- set them at the spec + 0.002 when at room temperature. Then you can rest easy -- they will be at spec when temperature reaches 190 �F.
Back to torque -- There seems to be this notion that tighter is better -- that being really tight is you best insurance of no leaks. This is poppycock. So many times excessive torque brings about distortion which, in turn, can increase probability of leaking. Think back to the days of the 57 Chevy valve tappet covers. Torque those babies down and you will have leaks big time! (PatB)
