620 propane
old Hank
07-01-2007 10:13:12
I need to drive a 620 propane tractor about
8 miles with a "Nurse bottle" connected
to the round fuel mixer (carb?) It runs fine hoocked up this way.
Question is, is this going to be a problem
going the distance?
big jt
07-01-2007 10:48:56
 Re: 620 propane in reply to old Hank, 07-01-2007 10:13:12
For Starters the round thing you are talking about is a convertor. All it does is convert the fuel from liquid to vapor and drop the pressure to just below the air pressure. It needs engine heat in the form of coolant to do this.
If all is otherwise hooked up as it should be get a nurse tank you can pull liquid from and you should be in good shape. If you have to use vapor there may be some problems getting enough fuel but this will only slow progress some. If you don't have major hills to climb you should be in good shape.
jt
big jt
07-01-2007 10:50:31
 Re: 620 propane in reply to big jt, 07-01-2007 10:48:56
I should add that I use a 20# cylinder with the older style valve and just turn it upside down.
jt
