4115 Not charging
Sam in MN.
06-30-2007 14:52:29
This may not be the fourm for this new of a JD, but I thought I would try. I have a 4115 JD that is not charging. Alternator tested good, new battery, new regulator, new Glow Plug Relay and both diodes. Checked every connection I can find. Can seem to get it to charge.....
Any suggestions?
Thanks,
Sam
buickanddeere
06-30-2007 17:50:29
 Re: 4115 Not charging in reply to Sam in MN., 06-30-2007 14:52:29
Will the battery charge with a jumper ran from the alternator's main post to the battery + terminal? Do you have access to an analog multimeter? Measure the alternator's, then the battery's + terminal with the engine shut off, engine shut off and all lights on, engine running at 1/2 speed & no lights, engine running 1/2 speed & all lights. Post back with what you find. There maybe a fusible link hidden in the wiring harness. If you ran the battery flat, then repaired the alternator, installed the alternator and jump started the tractor. Odds are you smoked the rebuilt alternator on the dead battery. A dead battery look like a short to the alternator and it will go onto a sustained max charge and smoke it's self. Before the battery takes enough charge to begin limiting the charge rate.
Sam in MN.
06-30-2007 18:24:49
 Re: 4115 Not charging in reply to buickanddeere, 06-30-2007 17:50:29
Buickanddeere,
This little Yanmar Diesel has a small thin alternator, that is putting out 28 volts AC at 2,000 RPM. Yes it is AC, not DC output. Per the local JD shop, that is right on the mark.
The connector out from the alternator, measures 0.05 volts with my digital meter on the battery or circuit side. Could be 0.00 depending on the accuracy of the meter or interference.
Battery is at 12.57 volts with the engine off, with lights on it drops to 11.95 volts. Engine running at 2,000 RPM, no difference at the battery.
buickanddeere
07-01-2007 06:39:27
 Re: 4115 Not charging in reply to Sam in MN., 06-30-2007 18:24:49
Something is off the mark. The alternator should be making 13.8 to 14.2V DC with a very slight ripple. No AC. An alternator tested with no load connected will show some strange voltages. There has to be a battery in the system. Sound like there is a break in the circuit between the alt + post and the batttery + post. The alternator maybe toast & the JD tech is completely & totally full of bull saying 28V AC is normal from an alternator. IF & IF everybody speaking the same language here. Using even a premium quality digital meter on a noisy electrical system will show odd results. A perfectly acceptable analog meter for machinery use is $10-$15.00 .
Sam in MN.
07-01-2007 18:41:19
 Re: 4115 Not charging in reply to buickanddeere, 07-01-2007 06:39:27
Buickanddeere,
This is the thing that is confusing me. The JD Dealer service tech, says AC volts, not DC. I asked him again and he confirmed 20 to 40 volts "AC" output from this alternator. If I check DC, it shows less than 1 volt output. Do you think he is full of crap?
I would just buy one and throw it in, but a new one costs $245. I have not been able to find a referbished one.
Maybe if I could get my hands on a wiring schematic or service manual, that would help. The manual is $140. Damn, I can't win.....
buickanddeere
07-01-2007 21:41:05
 Re: 4115 Not charging in reply to Sam in MN., 07-01-2007 18:41:19
Time to take that alternator to another shop with a load bank and find the facts. Those 20 & 35amp alternators are an odd looking little pancake unit. There appears to be no dedicated rectifier set of diodes in the alternator There appears to be no diodes hidden in the wiring harness either.I'm assuming the rectification & regulation is all handled inside the "regulator". Has the alternator ever been subjected to sustained/very heavy loads, a short circuit or reverse polarity?
430WLPG
06-30-2007 16:08:16
Did you check the fuses? Some of those tractors have a fuse for the exciter wire for the alt.
Sam in MN.
06-30-2007 16:30:34
 Re: 4115 Not charging in reply to 430WLPG, 06-30-2007 16:08:16
I have checked every fuse I can fine, some even twice. Unless there is one hidden I am not aware of.
Thanks,
Sam
