DLTX nozzle
TBJ
06-30-2007 11:55:31
Need help removing nozzle from dltx10 carb. Have tapped nozzle and tried both slide hammer and tap and washer to pull out nozzle. Soaked with BPblaster used heat, and patiently tried for a week to coax the sucker out, have cleaned the tube below the nozzle-nothing moves- I know I can drill it out but hate to destroy the nozzle, any suggestion will be appreciated. Thanks
TBJ
07-01-2007 07:14:33
 Re: DLTX nozzle in reply to TBJ, 06-30-2007 11:55:31
The carby-barby worked, cooked the carb yesterday afternoon and pulled the nozzle this morning. Thanks for all your advice. The tractor is a hand crank 1940 styled B that I pulled out of the woods. A total rust-bucker but a complete tractor except for tires and rims. I freed the pistons and valves, put new coil,points,condenser in magneto used 49 B carb from other tractor I own and she starts and runs good. The old gal still has a lot of problems but I think is worth saving.
P Browning
07-01-2007 07:31:53
 Re: DLTX nozzle in reply to TBJ, 07-01-2007 07:14:33
TBJ -- Thanks for sharing! How neat it is when things work out. (PatB)
F-I-T
06-30-2007 15:05:21
Don't be surprised if it takes a couple of heat-up-cool-down cycles. There might even be a burr on the edge of the casting that is creating a barb that is holding it back. Yes, I do use the charcoal grill trick, but sometimes I don't have the grill handy, I use a rosebud and get the ENTIRE casting pretty hot. Normally propane heat will be enough, and I think you should try that 2, maybe 3 times before you resort to anything hotter. You really have to be patient when using higher heat, and you should plop it in some clean, dry, kitty litter or cover it on both sides with a piece of trues fiber glass R-30 insulation for cool down, unless you have a thermal blanket like we used to used to cover dies during pre-heat in a large (2,000 and over ton) press.
I'm surprised that the tap-threads/slide hammer, or bolt through an arbor did not work. The brass is so conformable that it ought to walk it right out. Are you using as big a bolt as it will take? The inside portion of the nozzle is not calibrated, so for the portion that you thread, it will not hurt the nozzle at all.
Frank
TBJ
06-30-2007 13:24:36
Thanks all, Tried everything but the BBQ. Will try it next. Will let you know if it works. If dont work will just apply BBQ sauce and eat it.
P Browning
06-30-2007 14:07:35
 Re: DLTX nozzle in reply to TBJ, 06-30-2007 13:24:36
TBJ -- I wish you well -- 'reckon we will call this one the "Carby Barby"! We will be looking for your report. (PatB)
Jay Oakes
06-30-2007 12:29:26
Where did you heat the carburetor? I heat the area around nozzle after tapping the nozzle bottom with a 10-24 tap and apply pressure while heating-it may take repeated heating and soaking but it will come out. If the tractor runs fine when loaded you don't need to pull it-just blow it out.
CENTAUR
06-30-2007 12:17:23
Why does it have to be removed.I assume it is brass.Just Soak,rinse and BLOW OUT before it gets a chance to dry with high volume and the wetter the air the better. CENTAUR
P Browning
06-30-2007 12:53:51
 Re: DLTX nozzle in reply to CENTAUR, 06-30-2007 12:17:23
Rust formation in the acceleration well into which the fuel nozzle fits cannot be flushed or blown out, and no known solvent will disolve it. He is doing right to get the nozzle out and clean the accelerating well. I do agree the nozzle will not need much cleaning.
Heat will get the nozzle out -- and perhaps one of the easiest ways is to have dismantled the carb as far as you can go except for the fuel nozzle, and then start your BBQ grill up -- nice hot bed of coals! Gently position the carburetor body so that the part containing the fuel nozzle will get super hot. Close the lid and let it burn out. The next day, that nozzle should near about fall out! I give F-I-T credit for this one -- the neat thing about it is that it works! (PatB)
