Fit need your input on ppg vs dupont
Nylon
06-29-2007 23:28:13
I see in archives that you didnt like shooting the ppg. I have shot dupont centari and really liked it. It also has held up great on 76 dodge van. I have been steered towards ppg but it is a urethane and is supposedly a step up in grade. That may be true but I dont want a nightmare shooting the stuff. Both will be one step products ...not base clear. Not sure but thought you shot base clear. May be apples to oranges. About to buy paint and need to decide for certain here. Any input appreciated.
gurneejoe
06-30-2007 17:16:42
 Re: Fit need your input on ppg vs dupont in reply to Nylon, 06-29-2007 23:28:13
Hello again,
The synthetic enamel with hardener is high gloss and is very similar to Centari as far as looks and maintenance. Highly resistant to solvents and sunlight. It may need a wax job once in a while but it is the factory paint. You can't get much closer to matching that and still be original.
F-I-T
06-30-2007 20:00:21
 Re: Fit need your input on ppg vs dupont in reply to gurneejoe, 06-30-2007 17:16:42
Man, I want to get a hold of some of that synthol! I have painted Centauri, Synthol, Acrylic enamel from the big three, Deere brand synthetic, and ANY synthetic enamel, even with hardener, is at best, a 1965 annswer to paint technology. Even my Acrylic enamel is severely outdated, but since I live in the sun, I use that as my base, wet sand and clear coat, which I think is as tough as I need. I've shot some Imron, but my B-I-L shot thousands of gallons of it on the line, and painted a few airplanes out of his home shop with it, and both of us agree that it is pretty difficult to get good deep shine from Imron, if you can get a decent color match, since it cures and changes hues quite a lot. White Imron outsells everything else for a reason. With the cost of decent Limco 1-2-3 acrylic enamel gallon going for less than a gallon of Deere synthol, I just can't see trying to try to improve a synthetic with hardener when it has never performed up to an a.c standard mix for me. Different strokes, I guess. But if I want sun protection, it's either urethane, or a.c., then clear. They put clear on today's cars for a reason, and the paint lasts a whole lot longer these days and that's a fact. JMHO.
Frank
F-I-T
06-30-2007 05:52:44
I don't recall saying PPG was tough to use, just that I never found a "yellow" code in PPG and that's I used DuPont for the yellow. Typing on my PDA at LAX so this message will be short.
Frank
Nylon
06-30-2007 10:34:59
 Re: Fit need your input on ppg vs dupont in reply to F-I-T, 06-30-2007 05:52:44
Been through LAX alot. I call it moss iseley space port after the star wars bar scene.
Anyway thought you mentioned pinhole troubles with ppg in conversations with clooney.
gurneejoe
06-30-2007 04:55:52
I have painted a lot with Centari and some Imron and they are good automotive products but when it comes to the old tractors, I have followed the majority of the forum and have been using factory synthetic enamel with hardener with fantastic results. It is easy and forgiving to spray and it flows out very well to a smooth ceramic hard finish. I mostly use JD buff primer but on the wheels and sheet metal I used NAPA brand epoxy primer. High bucks but very good. Good luck and happy painting. It looks like I'm going to be painting the family room for my wife instead of tractor work today.
Nylon
06-30-2007 10:36:29
 Re: Fit need your input on ppg vs dupont in reply to gurneejoe, 06-30-2007 04:55:52
Does that synthetic fade..or does it hold up to the sun?
