BJohn Deere 2speed trans.problem
Dean in ks.
06-29-2007 06:48:03
I broke a casting that the gear shift goes into.Bought a used one put it in . can not get transmission to go into 2nd gearat all and it will not gocompletly into reverse. 1st gear goes into fine. Ive taken tower off and tried to slide gears all the way into reverse but wont go.
johns48jdb
06-29-2007 16:28:19
 Re: BJohn Deere 2speed trans.problem in reply to Dean in ks., 06-29-2007 06:48:03
not an expert, but put all the gears in netural and then put the shifter in where its in a netural position too. should work. you didn't drop a broken piece down in there did you causing the gears to lock up? better take a look at broken piece to be sure you got all the pieces that broke off.
